Question on a swap
Old Sep 20, 2007 | 09:09 PM
Civic Dx 349's Avatar
Member
Default Question on a swap
I have a Honda SI 1.6 Vtec that Im thinking about getting off my buddy. Its already in a 1995 Ex and I will have to take it out of his car (Ex) and put itinto my 1995 Dx 1.5 non-Vtec. What all is needed in order to get this to work correctly? Also, what's a good estimate on what it may cost me to have it put in?
Another thing. What would be the difference in just doing the head swap compared to the whole motor swap? Will there be a big difference power wise or no?
Thanks for the input guys!
Tim-
Old Sep 20, 2007 | 10:05 PM
that_guy5's Avatar
Default RE: Question on a swap
its called a mini-me u should just have to buy new seals and the ecu from the engine and wire up vtec, helped a buddy do it on his 97 civic not too hard http://www.jdmuniverse.com/forums/view.php?pg=minime
Old Sep 20, 2007 | 11:31 PM
Member
So will I get the same power gains whether I do the mini me or the whole swap?
Old Sep 22, 2007 | 11:31 PM
Member
Surely someone has to know! If I do the Mini me vs. the whole motor swap will it still perform the same? I wanting to go the route of just the Mini me head switchingcause its easier and cheaper but want to know if the performance is still the same going that route vs. going the route of swapping out and going with the whole SI vtec motor.?.?
Anyone?????
Old Sep 23, 2007 | 08:56 AM
PREKGSR's Avatar
im not sure about the whole mini-me but i would suggest to go with the complete engine swap. im just assuming this thoug
Old Sep 23, 2007 | 09:36 AM
technically, I believe you'll get more power out of a mini-me swap if both engines are the same size (since with mini-me swaps, you have slightly higher compression). But since you have a 1.5l, I'd say just swap in the z6.
Old Sep 23, 2007 | 10:42 AM
jason_guy_yeah's Avatar
I would swap for the d16 because, if you plan on doing aftermaket parts later. There's next to none for aftermarket parts for the d15b7 except for the jdm d15; which is identical to the d16.
taintedsaint
EG Swaps
May 16, 2008 04:46 AM
EKswapInfo
EK Swaps
Sep 26, 2006 05:33 PM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
