Really High Idle?
Old Apr 27, 2005 | 08:30 AM
DeiblerDelux's Avatar
Default Really High Idle?
Hey could use some help. I gotta really high idle whenever I start up my car and then after about 5 minutes of driving it will go crazy. Like it should start out at the 1 on the tach, but instead it starts on the 2. Then whenever I stop at a stop sign or red light it will start revings slowly from 1.5 to almost 3. It cant be good for my car. Just could use some insight on my issue. Thanks.
Old Apr 27, 2005 | 10:22 AM
ngoti 8tor's Avatar
Default RE: Really High Idle?
Definitely not good for the car!
Old Apr 27, 2005 | 12:28 PM
StifflersMom's Avatar
Cat Fuсker
Hmmm...bad O2 sensor? I'm probably wrong, but checking it doesn't hurt though.
Old Apr 27, 2005 | 05:55 PM
polo708's Avatar
shouldnt be an o2 sensor because when you are at low RPMs the ECU is in a preset "loop" and bypasses the sensors. Maybe something like dirty injectors, bad gas, or even bad spark plugs could be the problem. If it's during driving conditions then it could be the MAF sensor.
Old Apr 27, 2005 | 09:20 PM
fast93civic's Avatar
this is prob useless, but have you tried to reset the ECU by untying the negative ternimal on the battery?
Old May 2, 2005 | 09:31 AM
92jdmsedan's Avatar
i've had this happen to me a few times...its the thing on the bottom of the throttle body...i think its the idle-air control valve or something like that...my EG did it twice already and i had to buy new ones....
Old Jun 9, 2005 | 11:00 AM
ORIGINAL: fast93civic
I havent tried anything yet. I am just tryin to see whats going on with it so that I could fix it.n But I guess it really doesnt matter cause I just wrecked 3 days ago.
Old Jun 9, 2005 | 11:48 AM
neon3kgt's Avatar
Idle air control seems like a good place to start. and i thought it was in closed loop all the time, at work when i use the scan tool, its in closed loop no matter what if the vehicle is warmed up... are hondas diffrent?
Old Jun 9, 2005 | 11:53 AM
Cappelle's Avatar
totaled?
rad151
Apr 22, 2009 02:18 PM
krystencivic99
Jan 21, 2008 12:09 PM
tippr
Aug 6, 2007 02:29 PM
Partizan
Jan 25, 2007 09:13 PM
liliechen
Dec 25, 2005 11:15 AM
