Spending Money Wisely....
Old Jul 11, 2006 | 03:11 PM
DreamTeam87's Avatar
Default Spending Money Wisely....
If you had a honda civic with a d15b and $5,000 to preform upgrades for performance only without swaping out the engine what modifacations would you make? But if you would choose to swap out the engines deduct that from the$5,000.
List all prices beside each upgrade.
Old Jul 11, 2006 | 03:14 PM
ef4life's Avatar
Default RE: Spending Money Wisely....
turbo kit pieced together 800-1500 dollars
hondata - 600
good tune - priceless
Old Jul 12, 2006 | 12:18 AM
cyberx32's Avatar
hehe good tune priceless.
You also have to consider the labor costs if you decide to get the engine swap.
Old Jul 12, 2006 | 12:31 AM
AgentofDarkness's Avatar
Lets see if this one will work.
B18B1-$600
Rebuild Engine- $1500
Turbo Kit- $1500
ECU - 600
Other stuff - $1000
Total: $5200
Its a little over budget but not much. Labor not included and i prolly left out some stuff.
Old Jul 12, 2006 | 09:53 AM
omgxitsxaxhatch's Avatar
ORIGINAL: AgentofDarkness
B18B1-$600
Turbo Kit- $1500
ECU - 600
Other stuff - $1000
Total: $5200
^ agree... except h22 or k20 -h22 full swap = 2k.... k20 full swap= 3.5k
Old Jul 12, 2006 | 02:40 PM
joe383's Avatar
Member
$2,100 plus S&H I am guessing around $300 170 HP
B16A G2 Engine ECU (P30)
5 speed LSD transmission Distributor
Intake Manifold Exhaust Manifold
Injectors Starter
Alternator JDM Wiring harness OBD1
Power Steering Pump Half Shaft/Intermediate Shaft
A/C Compressor Throttle Body
Fuel Rail Down pipe
Sensors
50 HP dry kit NOS $550
Add about $1000 to that just for install and other little parts that might be missing
I would spend the rest on a traction bar $350
11” brake kit that uses my stock calipers $350
Sway bars front and back $250 = a grand total of $4900
Chadtheman
Dec 20, 2009 10:00 AM
Try.Fail.Repeat
Jun 18, 2008 10:10 PM
classiccarsrule85
May 19, 2007 06:42 AM
Street Sniper
Apr 20, 2006 11:20 PM
