Too many miles for turbo?
Old Feb 1, 2008 | 07:01 PM
megafandrew's Avatar
Default Too many miles for turbo?
MY 94 civic hatch has 120,545 miles on it right now. Would it be worth boosting it or should I just swap out the motor? How long could I expect it too last once turbo'd on a low boost level (safe level) like 6psi? Is this too many miles already to bother? Thanks
Old Feb 1, 2008 | 07:02 PM
FlipHKD720's Avatar
Default RE: Too many miles for turbo?
get a compression test, that'll let you know what kinda shape your engine is in
Old Feb 1, 2008 | 07:13 PM
alright, thanks flip
Old Feb 1, 2008 | 07:14 PM
actually I had one done a year ago when the car was bought, I will try to find the paper to see what it was at then.
Old Feb 1, 2008 | 11:14 PM
FlipHKD720's Avatar
if all the numbers are similar, you're good to go. Might wanna consider getting another one, have you run the engine hard in the last year? Wouldnt hurt....
Old Feb 2, 2008 | 06:20 AM
raz's Avatar
raz
I would at least prob do some internal upgrades just to be safe... cuz test can be wrong at times
Old Feb 2, 2008 | 07:38 AM
riceburner700's Avatar
i boosted mine with 170,000, ran good until i pulled it out. but do a compression check and if everythings good spend good money on the tune because thats what will tell you how long your engine will last
Old Feb 2, 2008 | 07:47 AM
Mr Mobsta Man's Avatar
Buy a compression tester because if you are boosted it isn't a bad idea to do compression tests somewhat regularly. Maybe like every month or two. You don't need to but it would help with piece of mind.
Old Feb 2, 2008 | 08:16 AM
thanks guys for the advice, and I will still find that old comp. test to see where it was a year ago and Ill have it checked again before i go blowing $$
winkosmosis
Dec 11, 2008 10:20 AM
Storms of War
Aug 31, 2008 11:31 PM
mentaldis0rder
Apr 21, 2006 08:22 AM
stonerdan
Apr 15, 2006 06:28 PM
stonerdan
Apr 14, 2006 04:12 PM
