Turbo...what next
Ok so after I get my turbo setup, I am going to need other pieces? What should i be upgrading I know the pistons and the rods should be upgraded, but what kind of ecu should i be going with the AEM EMS? And what things for the fuel system new rail? And what compression should the pistons be?
ya like he said EMS is extreamly expensive
i'de look into a set of 9.0:1 up to prolly a max of 10:1 with the upper CR you'll have to be careful b/c it will be easier to detonate with a lower octane fuel.
im doin .20 je srp pistons with je rings, acl bearings arp head/main/rod bolts, eagle rods in a jdm b16a swapped into my 99 si.
if i were you i'de lookinto hondata s300 get a p28 ecu outta a 95 civic hatch an obd2-obd1 conversion harness then have hondata solder the new board into the p28, with hondata your lookin at about 8-900 with that u get datalogging and all the stuff you'd need to tune it if you have a laptop.
you'll need new injectors look for a set of DSM 450CC/min outta a 2nd gen, an AEM Fuel pressure reg.
the stock honda fuel lines and rail are good to almost 400 hp with those injectors look for a resistor box so that way you can use the injectors b/c they arent the same as stock injectors their a different type, if you can afford it look into a set of RC engineering injectors. an aftermarket fuel pump wouldnt be a bad idea either.
and make sure you have enough fuel to support the pressure your goin to be running, the worst thing that would happen is you run outta fuel not literally but the max of the injectors and its goes lean...... and you figure it out lol what ive been doin is being over prepared with parets i usually wouldnt need to have, stuff like 700 or bigger injectors like im goin to be running i dont need them but i want the head room if i need it and so forth
