Valve Cover Question....
Old Dec 30, 2007 | 04:14 PM
jdizel's Avatar
Default Valve Cover Question....
Will a D16Z6 VTEC engine valve cover fit on a D16Y8 VTEC engine?
Thanks in advance!!
Old Dec 30, 2007 | 04:27 PM
jdizel's Avatar
Default RE: Valve Cover Question....
Figured it out...thanks
Old Dec 30, 2007 | 04:40 PM
ugh3012's Avatar
well. can't you at least tell us for some of us who may use the search button in the future.
Old Dec 30, 2007 | 05:46 PM
jdizel's Avatar
Yes...it will fit
Old Dec 30, 2007 | 06:18 PM
jdizel's Avatar
One more thing...how hard are they to install....and....if I get the one I'm looking for, how hard is it to paint it?
Old Dec 30, 2007 | 06:43 PM
GirlwithanSIattitude's Avatar
Valve cover is very easy to install. The hardest part is getting the damn thing off without getting any gasket in the cylinders...you gotta be careful, but yes its not a mechanical function.
Make sure you have a new gasket, RTV, scraper, acetone to clean off mating surface. My car is a VTEC Si, so my cover is different from yours, but its pretty much the same
I just did this last week, here is some pictures. Also go and download helms manual which is posted here on HondaCIVICFORUM...its 2200 pages in PDF. As far as painting the cover, do a search on the forum as I have seen several articles and posts from members.
Make sure you follow the torque pds and sequence
Old Dec 30, 2007 | 07:23 PM
riceburner700's Avatar
if you can have the outside of the cover sandblasted, it will give the paint something better to stick to. its fine if you cant. just clean the outside with some paint stripper and rinse clean. make sure you use high temp engine paint. most autoparts stores sell it in a variety of colors. If you know a powdercoater go with that, it will come out nice and glossy if you can afford it. theres some DIY's on how to paint your valve cover by the way floating around here.
Old Dec 30, 2007 | 07:32 PM
SovXietday's Avatar
5 bolts, and they're torqued to like 8lbs. Rule of thumb for them is to use a 10mm screwdriver and tighten them that way, just get them snug you'll snap them if you try to "bolt them down."
They take 20 seconds to pull on and off.
Painting them takes some practice, give it a try and give yourself some time to do a nice job.
Old Dec 31, 2007 | 02:41 AM
koots's Avatar
snapped mine, due to the rust. I wasalsoworkin them too hard and believe me, they are weak as hell and now i have one snapped off in the head.i guess the previous owner had neglected a few maintenance issues in the past...
Old Dec 31, 2007 | 08:28 AM
jamned's Avatar
There's some good penetrating oils out there that you can use to loosen bolts that are rusted tight. I use Kroil which is really good. This is assuming that you snapped the bolt removing it. If you snapped your bolt putting it back in, then that's a different story. You should've replaced the bolt if it looked rusted through.
Speed JUnkyz
Mar 15, 2010 03:34 PM
addiction2bass
Oct 9, 2009 03:25 PM
dazzdillinger
Sep 17, 2007 03:35 AM
WhiteRabbit1021
Jun 10, 2007 10:51 PM
mill$civic
Oct 31, 2005 06:25 PM
