vibration
Old Jan 28, 2006 | 08:11 PM
chaseman1978's Avatar
Default vibration
I just got my timing belt and balance shaft belt replaced todayon my Galant. The car runs fine, except for when I decelerate, when it gets to about 1000 RPMs it gets a slight vibration, only for 2-3 secs, then it's gone. We tore it back down after the test drive and re-checked the timing of the timing belt and the balance shaft belt. Both were dead on. Any idea's where the vibration could be coming from? It's not a real noticble vibration, but I know it wasn't there prior to the belts being installed...
P.S. If you wondering why I haven't put this on a Mitsu. forum, they are not to helpful Usually takes a couple of days to get any kind of response from there. Here , you guys are pretty quick to respond. And I feel more at home here too.
Old Jan 29, 2006 | 10:07 AM
Default RE: vibration
I think it has something to do with my idle. I've been watching the tach and when it starts the vibration, the tack starts to moving between 1200 RPMs and 800 RPMs. Once the RPMs settle, the vibration is gone. I'm wondering if the what ever controls the idle is going bad...
Old Jan 29, 2006 | 11:46 AM
riceburner700's Avatar
could be a bad ground!
Old Jan 29, 2006 | 07:37 PM
hadn't thought of that...But wouldn't the problem be more consistent with a bad ground? Not just around 1000 RPMs...
mahmi
18
Nov 4, 2006 08:30 PM
safian
Nov 7, 2005 01:37 PM
jbum
15
Oct 4, 2005 06:39 PM
US3R!!!11one
Jun 7, 2005 02:33 PM
kjreinha
Dec 21, 2004 03:24 PM
