steering wheel vibration and brake shimmy
I ran over a curb recently with my left wheels. I wasn't paying attention and ran over an island basically.
I got a wheel alignment and it showed that everything was within range except for the caster angle for the front left wheel. It was at 0.1 instead of some negative angle.
Lately, I've been noticing some brake pulsation when I brake (usually at higher speeds 40+mph) and
an accompanying steering wheel vibration. However, it seems to bounce rather than rotate back and forth
as in the case of a rotor warpage.
I've looked under the car and I didn't see anything unusual. Any ideas about what may be wrong?
John
John
When they did the alignment, did they balance the tires? If not, that might fix it. Or your tire could be damaged to the point that it needs to be replaced.
Yeah steering vibration is a sure sign of your tires being off balance. or you are just an idiot and put the wheel spacers on backwards... not that I've done that before or anything...
If the wheels were not balanced, I should feel the steering wheel vibrate by rotating right/left/etc. Also
it should vibrate like this regardless of braking or not.
This only happens while braking. Also, I put the affect wheel in the back and put the good wheel in the front.
I'm still getting the vibration while braking.
ORIGINAL: ngoti8tor
Sounds like a warped rotor to me.
