Vitara + Fuel Map
Old Jan 26, 2007 | 05:43 AM
cpl rampage's Avatar
Default Vitara + Fuel Map
ok, i bought an new d16z6 yesterday, im goning to be building it up over the next few months, and then turboing it.
my question is, if i put some LC vitara pistons in, and then put the whole thing in my car, without the turbo, just to break it in, do i need to change the fuel map? or can i get by with the stock map, and then change the map when i add the turbo?
Old Jan 26, 2007 | 02:24 PM
Default RE: Vitara + Fuel Map
anyone?
Old Jan 26, 2007 | 03:07 PM
Kedawei's Avatar
It might run, but it would run like crap. You'd be losing a full point in compression.
Old Jan 26, 2007 | 03:26 PM
i figured, thanks
Old Jan 27, 2007 | 10:10 AM
riceburner700's Avatar
it would run a little bit different but not a whole lot. you can break a motor in with low compression pistons in on a stock fuel map
rocksbite
Jun 29, 2009 01:06 PM
Max713
Dec 27, 2008 12:27 PM
stylincompact
Mar 30, 2007 10:13 PM
chrisbyers2005
Mar 19, 2007 07:07 PM
stylincompact
Sep 18, 2006 07:28 PM
