Vtec Conroller?
Old May 18, 2007 | 01:12 PM
2000 Si Newbi's Avatar
Member
Default Vtec Conroller?
I heard about this for the first time today. Only thing i heard is that it sets where your vtec kicks in. Mine is at about 5500rpm right now.
So question if you were to set it so your vtec would come into its own at like say 4500rpm would it make your car faster? Would it be bad for the engine(cams and stuff) to change it from stock setting?
Old May 18, 2007 | 01:45 PM
blackmetal619's Avatar
Default RE: Vtec Conroller?
well just remember, setting vtec earlier wont make you faster. Honda set it at the best possible time for a reason. I cant really go in depth, someone else will. Just dont mess with vtec
Old May 18, 2007 | 01:59 PM
Skrapdoggydog's Avatar
imo vtec controllers are a waste of money. the engineers at honda set the vtec engagement point at the optimum rpm for your engine, why change it? every sweet *** honda i've ever seen whether it is n/a orFIdoesn't ever have one. the cars that i do see have themarealways POS!spend your money on something else.
Old May 18, 2007 | 02:33 PM
Remmy's Avatar
Hey! I have one[>:]
Lol. But really, I have one built into my turbo setup but even I dont touch it.
Old May 18, 2007 | 03:10 PM
Member
well i tried to think about it. If the vtec kicks in earlier... then wouldnt that mean you get up to max hp faster? i forgot wat it was for the si.do i have the whole concept wrong when they say something like 160hp@7200rpm.
Old May 19, 2007 | 09:20 PM
Tegls1's Avatar
You will not get more power from your car or go faster actually you will loose power between 4500 to 5500 rpms. The factory vtec setting is program at that rpm because that is when the 2 HP line cross. That way you get a smooth vtec engagement and you get the full potential of your motor. If you you want get some dino pics of a vtec engine during vtec and without vtec. The engine produces more horse power when not in vtec under 5500 rpms the when in vtec. When the engine revs past 5500 rpms the engine starts to create more horsepower in vtec then when not. The vtec controller is actually not useless but is of no use on cars with stock cams. The vtec controller should be used with aftermarket high lift cams. the reason they are used is because both the smaller and larger lobes are enlarged to create more horsepower. If happen to have aftermarket cams the dino your car and where the 2 horsepower lines cross is where you should set you new vtec changeover point.
Old May 20, 2007 | 10:07 AM
dragoncivicsi's Avatar
nice info... i want a new cam an a controller now.
Old May 20, 2007 | 12:04 PM
Marty's Avatar
ORIGINAL: Tegls1
ok I'll get right on that
All vtec does is make it available to run larger duration lobes on the top end w/o screwing up milage and driveability in the lower rpms.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
88civicjordan
Mar 2, 2006 09:12 PM
ryantann
Feb 21, 2006 09:50 PM
mahmi
Aug 25, 2005 09:39 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
