vtec eleminater cams??
Old May 6, 2006 | 04:45 PM
nwhite82's Avatar
Default vtec eleminater cams??
what dou tou gauys think about these cams???
http://www.dh-racing.com/cams.html
Old May 6, 2006 | 06:19 PM
Nail I3unny's Avatar
Default RE: vtec eleminater cams??
theyre pretty good. they work by having both the normal and VTEC lobes the exact same, so its no different from unplugging the vtec solenoid and getting a bigger non-vtec cam (which is prolly cheaper)
thats about all i can tell you. theres been some discussion on them about it around here...try searching a bit.
Old May 6, 2006 | 07:44 PM
finalimpact's Avatar
actually the vtec killer cams(same as these) do not have the center vtec lobe. this helps with reduced rotational mass and weight. but, these cams are designed for high rpm usage. its basically like going with an all motor ls set up with massive cams but with a better flowing head. low rpm power is sacrificed for mid to high rpm power. great cams if you really dont care about low rpm power and want that oh so sweet lumpy idle
Old May 7, 2006 | 05:39 PM
good for drag racing apps.
ps thats basically what i said...'no vtec lobes' v. 'vtec lobes same height as non'
Old May 7, 2006 | 08:26 PM
ORIGINAL: Nail I3unny
[8D] they only have 2 lobes per cam per cylinder [8D] but were both on the same page
joshhondacivic
Jan 31, 2008 04:58 PM
evotechnik
Sep 17, 2007 04:36 PM
Mister_JDM
Nov 24, 2006 09:03 PM
mikecivex
May 27, 2006 03:31 AM
nwhite82
May 6, 2006 04:46 PM
