what causes oil in the engine coolant?
Old Aug 6, 2005 | 02:20 PM
importcivicus's Avatar
Default RE: what causes oil in the engine coolant?
Next thing you turn your back and I escape to save my VTEC *****.
Old Aug 6, 2005 | 06:11 PM
Kappa22's Avatar
Thanks for the backup, pcupo, but I'm not really going to jump on everyone who says it, especially if they're just trying to provoke someone. It's more of the Panopticon effect... if the masses live in fear or uncertainty, they will govern themselves. (Wow, that's like a policy line from the Bush administration...)
Old Aug 8, 2005 | 09:18 PM
93SiHb's Avatar
im not to sure on wut you mean by grimmey but the oil is very dirty in the dipstic dispite doing a full on oil change 2 weeks ago also i have not yet taken it appart for inspection but im planning to this weekend my dad also thinks th head might be warped so i will be pulling it off and checking for straightness and cracks but im hoping its just the gasket cant afford an engine rightnow
Old Aug 10, 2005 | 12:03 AM
sacicons's Avatar
if the heads warped, just get it milled by 10-20 thousandths. that will also bump your compression up enough to make noticeably more power too. should only cost about 30-50 bucks. 20 or more and you need to bump your octane to at least 89. more than 30, and its premium for you.
Old Aug 10, 2005 | 04:23 PM
93SiHb's Avatar
i think i can get it milled for free im gonna make the dissasembly this weekeend and see wuts up
Old Sep 10, 2005 | 10:48 AM
93SiHb's Avatar
k havent taken it apart for the reason i need it for work but i did do a compression check and looks pretty bad starting from the 1st piston to the right its 150 60 150 100 what do you guys think also the one with 60 it was a ****en pain in the *** to take out the spark plug
Old Sep 10, 2005 | 01:34 PM
ngoti 8tor's Avatar
ORIGINAL: pcupo12
*Pcupo12 detains you.....cuffs you to a bench, where you shall await castration!*
I see a pattern here.......petey seems to like touching guys *****.
GenePro
Jun 16, 2012 09:49 AM
paak
14
Nov 19, 2011 02:24 PM
Viral Sanchez15
Aug 7, 2010 12:10 PM
oilltd
Jun 10, 2008 04:06 PM
