What would be the benefits?
Old Dec 4, 2005 | 01:43 AM
JonesEK's Avatar
Default What would be the benefits?
Well I was thinking what would be the Benefits of upgrading my stock Pulleys . Also the same question for the Camshaft, and Cam gears. And How much power will it add, If any. Well thanks for your help! Does anyone know any good brands? I know the for the Cam gears AEM makes some good ones. BTW my cars an 00 EX
edit: ALso was thinking of upgrading my pistons.. But thats a bit later. Suggestions?
Old Dec 4, 2005 | 11:27 AM
fast93civic's Avatar
Default RE: What would be the benefits?
Pulleys will give you minimal gains, and Id say are not worth it till you get everything else done. Cam gears are the same, first get cams. Camshsafts are a good idea, they would give you the most power from all the other things you've listed. But first have atleast i/h/e before you get in to cams. You wont need to upgrade the pistons unless you're going F/I or a really heavy duty N/A build.
Old Dec 5, 2005 | 04:02 AM
tekk220's Avatar
dont wanna sound stupid... but what n/a and f/i
Old Dec 5, 2005 | 07:40 AM
F/I = Forced Induction (i.e. Boosted, Bottled or Blown, or in english, Turbo, Nitrous, or Supercharged)
N/A = Naturally Aspirated (i.e. None of the above/All motor)
Old Dec 5, 2005 | 12:03 PM
Kappa22's Avatar
I wouldn't touch your alternator or crank pulleys.
Old Dec 5, 2005 | 12:47 PM
Marty's Avatar
Pullies are a waste of time and money on a honda
Old Dec 5, 2005 | 05:32 PM
Kappa22's Avatar
ORIGINAL: md420
[sm=exactly.gif]
Old Dec 7, 2005 | 05:56 PM
Jason's Avatar
go cams but i dont recommend over a "280" grind for the street above this and you lose vacuum and idle quality and a manual tranny or stall converter becomes mandatory, get your CAI header and exhuast done first before you change the cams though otherwise you wont be able to really feel how much the cams are "worth" port, portmatch and polish the head next, have fun with it.
Jason
95 DX
83 RX7
megafandrew
Jan 23, 2008 02:54 PM
burgernuds
Jul 30, 2007 09:45 PM
ef4life
Jul 26, 2007 09:11 AM
Faithbleed
Oct 16, 2006 06:43 AM
duffycivic
Aug 6, 2004 10:55 AM
