Z6 to Y8 swap
Old Jan 19, 2005 | 08:21 AM
StifflersMom's Avatar
Cat Fuсker
Default Z6 to Y8 swap
Allright, I might not be the brightest person out there, but lemme ask this. A Y8 is a better designed head from what I understand, but the compression is higher. If I swap a Y8 instead of my Z6 will I be able to somehow lower the compression back to where it was?
Old Jan 19, 2005 | 02:06 PM
fast93civic's Avatar
Default RE: Z6 to Y8 swap
why would you wanna lower the compression of the head when thats the whole point?
Old Jan 19, 2005 | 02:31 PM
hondabboy's Avatar
it depends man like if you want lower compression just stick with the z6 i mean its the same thing as the y8 just the y8 is better because it has more compression for all motor requirements. so yes its a good swap if you want to.
Old Jan 19, 2005 | 07:51 PM
Cat Fuсker
As I understand the Y8 is less prone to detonation, but the compression is higher. So I was wondering is I could run higher boost with that quality of the Y8 head.
Old Jan 19, 2005 | 09:19 PM
sacicons's Avatar
with the slightly higher compression, the slightly lower boost will make the same power. just lower the boost by .5 psi or so.
Old Jan 19, 2005 | 09:50 PM
Cat Fuсker
Ok, now I realize that what I though made no sense...
Old Jan 19, 2005 | 10:02 PM
Kappa22's Avatar
No worries...
Old Jan 19, 2005 | 11:32 PM
sacicons's Avatar
a lot of people lower the compression too much for boost. for them, its usually about bragging numbers, not driving. yeah, a T4 might make some nice hp numbers pushing on a built sohc at 8:1, but most of us would hate driving it every day. youre better off with the higher compression and low boost from the smallest turbo you can get that will flow enough for your motor. it will spool fast and still have good top-end power.
Old Jan 20, 2005 | 01:56 AM
Kappa22's Avatar
T25...
Old Jan 20, 2005 | 08:32 AM
sacicons's Avatar
my thoughts exactly.....
taintedsaint
EG Swaps
May 16, 2008 04:46 AM
EKswapInfo
EK Swaps
Sep 26, 2006 05:33 PM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
