91dx timing problem?
Old Feb 23, 2011 | 01:11 PM
theRDRman's Avatar
Exclamation 91dx timing problem?
yeah my 1991 dx has a 1.5l in it. i filled my tank up the other day. i have travveled 140km and i have gone threw half a tank of gas. what could be causeing this bad timing or something else?
Old Feb 23, 2011 | 03:33 PM
MBrent's Avatar
July 2010 ROTM
theres more than a couple things it could be. first off, hows the car running? roughly? smoothly? a tune up can always help. if the tune up fixes it, great. if not, odds are it needed a tune up anyway, so the money wasnt wasted. check your usual parking place for signs of a petrol leak. look under the hood, any signs of leakage around the fuel filter canister? im unfamiliar with the fuel system on a dpfi car (after the filter canister), so maybe someone else can help you with places to look.
Old Feb 24, 2011 | 08:24 PM
theRDRman's Avatar
yeah it did have a fuel leak under the back seat where it had to be cut out. it smells of gas but no visable leak. and how much would a tune up be in canadian$???
Old Feb 24, 2011 | 08:51 PM
dpfi and mpfi have the exact same fuel system, just dpfi only has 2 injectors and no fuel rail.
what had to be cut out??? if you smell gas you have a leak
Old Feb 24, 2011 | 09:16 PM
theRDRman's Avatar
the fuel line under the car was rusted out. and we put in rubber hose... i see no gas leaking anywear i can smell it from time to time tho
Old Feb 24, 2011 | 09:36 PM
thats the problem, that rubber hose isnt designed to hold the high fuel pressure.
Old Feb 25, 2011 | 05:36 AM
+1 Don't try to patch the fuel supply lines. The pressure will blow ordinary rubber fuel line hose, which is for carburetor systems that are basically gravity flow or a small pump-- not 40 or 50 psi. There is special high pressure fuel injection rubber hose but it should only be used to replace OEM rubber hose (which mice love to eat for some reason), not clamped onto old lines under the car.
Fuel leaks are serious business. When there's a traffic jam because of a car on fire it's often because the owner ignored it "smelling of gas from time to time."
Old Mar 2, 2011 | 01:23 PM
theRDRman's Avatar
my car is messed im pissin tranny fluid and motor oil and its messed up. i donno what to do
smackpower
Jan 13, 2024 01:42 AM
roblinxs011087
Feb 19, 2007 08:39 AM
timtimmah
Feb 15, 2007 03:55 PM
timtimmah
Feb 15, 2007 11:41 AM
2hpr4u
Jul 28, 2006 05:16 PM
