Amp Cable Run Question
Old Nov 1, 2010 | 06:40 PM
m@nny's Avatar
Default Amp Cable Run Question
ok, i got an 00 civic ex coupe, and im putting in a system in the trunk, i got all the materials, im just having a hard time finding the hole where the power cable is gonna go from the battery to the amp, can anyone help me or tell me how you have done it to get it from under the hood to the inside of the car? thanks
Old Nov 1, 2010 | 07:40 PM
Is your car an automatic or manual? Most commonly (at least on automatics), you can run the power cable through the rubber grommet that covers the hole that's meant for the clutch master cylinder of a 5 speed. From the engine bay, it's located just to the right of the brake master cylinder.
Old Nov 1, 2010 | 07:46 PM
DaOne's Avatar
The way i did it on my 93 civic was thru a small whole below where the battery sits.
the whole went to underneath the glove box area..
Try looking on the firewall for holes where cables go into the cabin. and just squeeze the power cable in one of them
Old Nov 1, 2010 | 08:41 PM
Remove the battery and metal tray (just a couple bolts). There is a rubber grommet as DaOne mentioned. I cut a small slit in the rubber under the OEM wiring and snaked the power cable through there.
Afterwards, I took put some black silicone sealant on the rubber grommet, around the cable and hole which was made. That part can be skipped though.
Old Nov 1, 2010 | 09:25 PM
Superfly's Avatar
^Thats what I did on my 99 lx
Old Nov 1, 2010 | 09:41 PM
TiggerDX's Avatar
I did the same on my 94. But I was able to reach the grommet without removing the battery. It was just below and to the side of the battery.
Old Nov 2, 2010 | 08:20 AM
m@nny's Avatar
ohh ok! im gonna try that, btw its a manual transmission, thanks guys
groupwest
Feb 5, 2008 09:30 PM
xsdudztx
Aug 9, 2007 07:45 PM
samilitant
Jan 8, 2007 10:47 PM
Remmy
Mar 6, 2005 01:18 PM
spevie
Mar 1, 2005 06:48 AM
