Any idea how much HP?
Old Nov 24, 2005 | 03:36 AM
  #41
Kappa22's Avatar
Default RE: Any idea how much HP?
Well, since you're the resident header guru now, you should also know that the Hytech headers require you to remove your A/C and PS pumps... not very likely for a daily driver, especially not one driven by the lovely 2000 LoW reD Si.
Now that I got that out of the way, I did a Google search out of curiousity, and I found the article you're jacking all your "information" from:
http://www.tprmag.com/issue/10/10_b16_headers.shtml
[sm=owned.gif]
Only slightly less obvious than Super Street... I don't even have to dish any more dirt here; the damage is pretty much self-inflicted
Old Nov 24, 2005 | 03:45 AM
  #42
StockSi's Avatar
ORIGINAL: Kappa22
[sm=owned.gif]
dude, please release my dick! how in the **** would a header on a Si require you to remove the power steering pump?!? are you f'ing serious? where are you getting your info from!!!!? i've been doing this for more years than i can count on one hand and you don't need to remove the a/c pump either!!! damn. remove the a/c and ps pumps for a n/a header!?!?!?!?1 please! get a clue.
Old Nov 24, 2005 | 03:56 AM
  #43
Kappa22's Avatar
Hahaha... like I said, if you know, you know. If not, it's awfully hard to pretend.
Most Hytech headers are developed for drag/track use, and DO require you to remove your A/C and PS. But, since HyTech products are almost all custom jobs, some are made to accomodate the pumps, though they probably won't perform as well as the numbers you see in the side-by-side tests.
I'm pretty sure this is the header you're thinking of... now do you see?
http://www.redshiftmotorsports.com/images/hdrag.jpg
Old Nov 24, 2005 | 04:12 AM
  #44
StockSi's Avatar
um... that picture is of a header for a longitudally mounted engine.. like in a s2.. that, or it exits a civic in front of the front tire. it does look like John made it tho. yah.. so the hytech header for a b-series looks like this:
or,
Old Nov 24, 2005 | 04:19 AM
  #45
StockSi's Avatar
^ either way you look at it you're venturing into areas you have no clue about.. you just keep on loveing greddy crap.
edit: that and, you're a fool if you can't tell that that header isn't made for a streetable b-series.. if it is even for a b-series.
Old Nov 24, 2005 | 04:20 AM
  #46
Kappa22's Avatar
S**t. My bad. That's a HeaderTech, not a HyTech.
Old Nov 24, 2005 | 04:25 AM
  #47
Kappa22's Avatar
Hahaha... you're right, I have no clue what I'm talking about, while you are clearly Jesus on a power trip.
That said, you still don't realize that the way HyTech gets those shiny looking power gains is without PS or A/C.
Old Nov 24, 2005 | 04:27 AM
  #48
Kappa22's Avatar
ORIGINAL: StockSi
And I said so myself, it's a DRAG header... when was the last time you drove a strip car to the mall?
  #49
StockSi's Avatar
ORIGINAL: Kappa22
sorry, i'm an aetheist.. call me your dad instead.
that said.. both the header pics i posted will outperform your greddy piece and retain a/c and p/s. thanks.
Old Nov 24, 2005 | 04:30 AM
  #50
Kappa22's Avatar
For starters, I don't own a Greddy "piece," which you have obviously never had any experience with.
And second of all, HyTech sure as f**k doesn't make turbo manifolds for an RB26DETT.
