Clutch cable or not?
Old Sep 2, 2006 | 05:34 PM
ryank327's Avatar
Default Clutch cable or not?
Well I cant drive my car because I cant shift. I have had 2 mechanics tell me its the clutch cable. SO would this be a clutch cable?
http://cgi.ebay.com/ebaymotors/Clutc...QQcmdZViewItem
Old Sep 2, 2006 | 06:09 PM
01silverbullet's Avatar
Default RE: Clutch cable or not?
I dunno but that looks like it is some sort of cover for the cable. just my 2 cents but i dont know.
Old Sep 2, 2006 | 09:04 PM
Solid_Snake's Avatar
no, the auction says it is a hydraulic clutch line
Old Sep 2, 2006 | 09:23 PM
Intrepid175's Avatar
ORIGINAL: ryank327
As Solid_Snake said, the auction identifies the part as a hydraulic line. You don't mention what year model your car is? If it's got a clutch "cable" then you don't need any hydraulic lines. If your car does have a hydraulic clutch system and you've got two mechanics telling you that you need a "cable," I'd RUN, not walk away from those guys as "fast" as I can!
Look under the hood and check to the left of the brake master cylinder. If you see a second master cylinder, smaller and a bit lower than the brake, then you've got a hydraulic clutch system. If not, then you may well need a clutch cable.
Good luck,
Steve R.
Old Sep 3, 2006 | 10:06 AM
ryank327's Avatar
I have a 99 si
fletch92hatch
Dec 25, 2007 05:24 PM
xsdudztx
Aug 9, 2007 07:45 PM
jtvision
Jan 11, 2007 07:58 AM
95dx28
Mar 7, 2006 10:46 AM
spevie
Mar 1, 2005 06:48 AM
