Clutch fluid -- to change or not to change
My car is going in for service shortly and I'm having them change brake fluid, etc. Well, my clutch fluid is 5 years old and looks a bit contaminated. Should I have them flush it out, or is this not worth it?
Thanks
Thanks
For the brake fluid, get a friend and do it yourself, its not that hard(unless you don't have a garage or have a cold garage like me). I guess you could do the clutch, but i have never worked with a manual trans clutch.
if your car is going for service at a dealer, then they have a machine they use to flush out your entire brake system. it works very well, compared to a drain and fill in your driveway. the same machine would be able to do the hydraulic clutch fluid ecause it is the same as the brake bluid (well pretty much the same they are both hydraulic).
Couldn't you just bleed the brakes until the fluid is the same color as it comes out? Its prolly cheaper than paying the dealer to use thier fancy machine to do it.
enigma34
May 13, 2009 06:41 PM
mundy5
19
Jun 29, 2008 04:58 PM
iwishiwasemo89
16
Jul 27, 2007 12:27 PM
iwishiwasemo89
Jul 27, 2007 12:07 PM
