D16Z6, good or bad
Old Oct 21, 2004 | 06:51 AM
spevie's Avatar
Default D16Z6, good or bad
Just to ask, my 93 civic esi has the D16Z6 stamped on the plate, is this a good engine or prone to stuff failing, what exactly does this D16Z6 stand for....
spevie
Old Oct 21, 2004 | 08:25 AM
2000Si's Avatar
Default RE: D16Z6, good or bad
It's a Honda, **** isn't prone to failing on a Honda motor... that is as long as the motor has all it's normal maintenance.
D16z6 is the engine code, It's a D series (SOHC vtec) that is a 1.6L 4 cylinder. z6 is just the specific designation.
Old Oct 21, 2004 | 06:34 PM
sacicons's Avatar
it is the second best SOHC motor. it is lightweight, powerful, efficient, and responds to mods well. if its got to be SOHC, then thats a good one to have. the only one really any better is the d16y8. it has slightly better head chamber design, but its not a big deal. if you can find a y8 head, you could put it on your motor and it would be great.
Old Oct 21, 2004 | 09:18 PM
2000Si's Avatar
Also, the d16y8 is obd2 compared to the z6 being obd1. and the y8 produces 2 more hp and 1 more ft lb, not that that makes any difference at all.
Old Oct 21, 2004 | 10:05 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 22, 2004 | 02:12 AM
spevie's Avatar
Cheers guys, understand a bit better now.
So the engine is a good one, responds well to mods, its a OBD1 so any mods i see for a OBD1 series then i can do to mine.....I was reading info about ECU upgrades and it referred to OBD1 type ecu chips, so i can do stuff to my ecu with the OBD1 spec....?
Many thanks
spevie
Old Jan 13, 2021 | 01:48 PM
Justin Simons's Avatar
No way Z6 is best sohc you can get in the Ds. Been proved. So says the y8 has cpl more horse doesnt mean its above. The best route between the 2 is puttin the y8 intake maifold onto the z6
killamerk
Oct 19, 2007 08:52 PM
Inev
Mar 23, 2007 06:43 PM
Ek98
Nov 30, 2006 12:43 PM
Ek98
Nov 27, 2006 11:18 PM
hondaz6lx
Jan 11, 2006 01:51 PM
