fastest engine you can put in 96-00 civics?
Old Aug 8, 2011 | 09:13 AM
hondacivicenthusiast's Avatar
Default fastest engine you can put in 96-00 civics?
i want more horsepower, and i was curious what is the biggest and fastest engine you can put in a 1998 honda civic?
Old Aug 8, 2011 | 10:20 AM
Biggest I would imagine is the 3.2L V6. Probably bigger with more modifications.
K20/K24 would be the next "biggest/fastest" I think
H22
B18c1
B16
That is my order of motors. The higher you are on the list, the more expensive it will be.
Old Aug 8, 2011 | 10:55 AM
I saw on ebay a K20 engine with a 6 speed manual trans, is it possible to put that in?
Old Aug 8, 2011 | 11:19 AM
MaximusFunk's Avatar
depends on your budget and patience. I saw a youtube video of a civic with a chevy small block in it.
Old Aug 8, 2011 | 12:41 PM
Yes. Do some research to determine what is best for you money-wise, and power-wise.
Old Aug 8, 2011 | 02:47 PM
I'd say a K-series will be the biggest/fastest you'll be able to swap in without a lot of work. It's not as easy as a B-series swap (pretty much a bolt-in if you have all the right parts), but it wouldn't be anything like a J-swap.
If it helps, the price of K-swaps has come down considerably in the last few years. You'll still need swap-specific mounts and axles though.
Old Aug 8, 2011 | 08:35 PM
Shandles's Avatar
H22
B18c1
B16
Honestly, I'd say that the H22 is cheaper than the B18c. I can find a H22 for less than $500.... but I haven't seen a B18c for less than $1500. Maybe its just something to do with where I live? I dunno. And the mounts for both engines cost about the same if you get them from Innovative or something.
If you're going H2B, then yes... its probably more expensive than just a straight B18c but you also get another 30 lbs of torque and 10-20 hp depending on the engines... (b18c is 170 hp max while H22 is 170 at the lowest)
Old Oct 3, 2019 | 05:28 AM
Jose Perez's Avatar
When you say its not as easy as a B swap, do you mean that the original mounts from the dy16 fit on the B series motor?
Old Oct 3, 2019 | 07:54 AM
StifflersMom's Avatar
Cat Fuсker
No they don't fir to a B, still need mounts. H is geometrically bigger and just leaves you less space to work with plus whatever else.
Old Oct 3, 2019 | 12:48 PM
Jose Perez's Avatar
O ok.. yeah I see. Thank you
Fastasscivic8723
Jul 7, 2008 11:11 PM
mastersjose77
Jun 22, 2008 10:20 AM
Lost
Apr 23, 2007 04:51 PM
krentigrboi
EK Swaps
Nov 12, 2005 11:58 AM
vythai28
EK Swaps
Jul 18, 2005 10:17 AM
