Neewwbie Question- Major tune up- swap out ignition coil too?
Old Jan 23, 2007 | 11:19 PM
cruzncivic's Avatar
Default Neewwbie Question- Major tune up- swap out ignition coil too?
Hey wazzzzup everyone im new to the site and i like it!!!!!!!!!! Im rollina 98 civic andmy Q&A is: Im about to hit the 80,000 mark and need to swap out cap rotor plugs and wires but if my ignition coil is bad would i still getspark or absolutely no spark???
Old Jan 23, 2007 | 11:20 PM
sacicons's Avatar
Default RE: Neewwbie Question- Major tune up- swap out ignition coil too?
you might get a weak spark even if the coil is bad.
Old Jan 26, 2007 | 05:45 PM
Powermidget's Avatar
If the coil is going you'll get a spark then one day your car wont start...happened to one of my crx's....replace it with an msd external coil when you do, i spent almost as much replacing the stock one
Old Jan 28, 2007 | 09:03 PM
halfnoise's Avatar
my car just hit 100k, so bought a nice lil tune up kit..
replaced everything between the stock coil to the plugs.. (rotor, external coil, dizzy, wires, plugs.. all MSD)
came with a neat-o see thru distributor..
what was really great, I hooked up my stock coil with the new dizzy...checked out the spark on the cap and rotor...then wired up my external coil (MSD Blaster 2)
and the spark was much bigger inside the dizzy.. probably going to change the gap on my plugs because of it..
anyway, I'd recommend getting an external coil. my car idles a bit smoother.. that kinda thing..
trx680
Feb 25, 2014 07:14 PM
Joey Gamblin
May 17, 2012 06:54 PM
jaf2000
Apr 20, 2012 08:35 AM
kma
Oct 30, 2007 11:16 AM
cdfrnk
Mar 16, 2006 11:58 PM
