The official un-ricing of the Civ (or an attempt)
Old Jun 5, 2007 | 11:12 AM
  #291
mybrokenblinker's Avatar
Default RE: The official un-ricing of the Civ (or an attempt)
I'm still having an issure with my cel coming on every other week with the code 45 which is running too rich or too lean. I don't know if a new primary 02 sensor would solve it, or if i should just get an 02 simulator. I don't know which sensor is causing the issue. I might just get the new primary since it can't hurt, they need to be replaced anyway, and if that doesn't fix it, maybe get the simulator.
Old Jun 5, 2007 | 11:43 AM
  #292
FlipHKD720's Avatar
you install the o2 simulator on your secondary sensor's signal. What does your CEL say? Usually it will specificy if its the primary or secondary o2 sensor.
Old Jun 5, 2007 | 05:39 PM
  #293
Maiko's Avatar
not 2 bad but u have to change u're headlights back to stock or put a type r (pls not those ebay type r)
Old Jun 5, 2007 | 06:39 PM
  #294
WTF ya still havent instaled the stechs yet......
you lazy B***ARD. LMFAO
just cross your fingers and hope your rear lower control arm bolts come out with no problems.... but id still suggest new ones for the strut... after i removed mine the threads didnt look to great... just added security against striping them out with reinstaling..
Old Jun 5, 2007 | 10:12 PM
  #295
ORIGINAL: FlipHKD720
Yeah i know the simulator is for the secondary signal, my problem is i don't know which one is throwing the cel, just says "too rich or too lean" (i can tell it's too rich). So i figure i might just try replacing the first (it can't hurt and most people get better mileage from replacing it on older cars) and if that doesn't fix it, I can get a hi-flow cat and an o2 simulator.
Old Jun 6, 2007 | 04:36 AM
  #296
cderalow's Avatar
i run a high flow on my DX, no CEL.... learn to place your O2 sensors properly :-P
Old Jun 6, 2007 | 07:14 AM
  #297
mxs's Avatar
mxs
ORIGINAL: mybrokenblinker
the PRIMARY determines if your car is running too rich or too lean. The ECU uses this signal to adjust fuel
the SECONDARY tells the car that the cat is working! that's all it does. it doesn't care about air/fuel mixture
Old Jun 6, 2007 | 01:16 PM
  #298
FlipHKD720's Avatar
ORIGINAL: cderalow
is it a name brand? I've got a freakin "ebay" high flow cat/test pipe on mine, it doenst do sh*t for emissions, thats why my CEL is telling me my cats efficiency is basically worthless...w/e though, simulator is on it's way.
and addiction i know i'm a lazy bastard hahaha Prom/graduation/paying off a ticket stopped me from having ANY money to spare, but finally its summer, compressors are on their way, and i got lots of time to install. When installing my short shifter i used Liquid Wrench and it loosened up some bolts that were really rusted, hopefully it'll work on the LCA bolts as well
and since i'm here, i ordered a T25 last night no shaft play, $80 shipped from a guy on Turbod16.com. Now comes the rest of the kit: https://www.hondacivicforum.com/m_43.../tm.htm#434923
Old Jun 6, 2007 | 01:55 PM
  #299
i still dont see why ya cannt just go to autozone and rent one of thier compressors....
i was gonna buy them from autozone but after thinking about it i was like F it... i want my money back.LOL and took it back... its just 2 threaded shafts and tips on each end...... tho having a air wrench helps ALOT QUICKER. LMFAO
first spring i did manual wrench... then i was like F this i got air tools. LMFAO
Old Jun 6, 2007 | 03:27 PM
  #300
FlipHKD720's Avatar
yea i got air tools. Idk why nobody will rent them out, but w/e, now i'll have them for my own. Maybe i can rent them out to my friends
