Regular to Synthetic
Old Mar 6, 2006 | 09:14 PM
d2privat11's Avatar
Default Regular to Synthetic
I was reading older threads about motor oil and the difference between synthetic and regular and I came across one post saying that they heard that if you had been running on regular for a while and then switch to synthetic that it could cause problems, is this true?
Old Mar 6, 2006 | 09:24 PM
sacicons's Avatar
Default RE: Regular to Synthetic
only if your motor uses or leaks any. its thinner than conventional oil, so it will leak and burn way faster than conven oil.
Old Mar 6, 2006 | 10:05 PM
cloudbreakmd's Avatar
Actually we talked about this on my motorcycle forums too...
This might help:
http://www.quakerstate.com/pages/carcare/whattoknow.asp
Old Mar 6, 2006 | 10:09 PM
Old Mar 6, 2006 | 10:10 PM
civicexracer's Avatar
I have heard of switching from reg. to synthetic can cause leaks. If u are having any kind of leaking with the oil u are using now, expect more if u use synthetic since it is thinner. I wouldnt change just to be on the safe side, not worth going thru all the hassel IMO.
Old Mar 7, 2006 | 08:40 AM
Kedawei's Avatar
If you change all your seals and gaskets, can you make the change without worry?
Old Mar 7, 2006 | 10:59 AM
You can change from mineral to synthetic and vice versa. Think synthetic blends that are offered otherwise.
DaCapitan
Jun 11, 2012 12:24 PM
thedmanhere
Jul 21, 2011 04:28 PM
curlybandit
Jul 20, 2006 02:39 PM
platatoos
May 24, 2006 09:19 AM
maddawg
Jul 21, 2005 12:17 PM
