Speedometer not working?
Old Oct 14, 2009 | 04:09 PM
NyTreCivic's Avatar
Post Speedometer not working?
So i need to pass a car inspection and suddenly my speedometer just started going crazy. moving up and down rampid. Any easy ways to fix this problem? my dash works fine all other gauges work fine its just my speedometer isnt. Plz help or provide advice.
Old Oct 14, 2009 | 07:53 PM
supersize's Avatar
Sir Banned-a-lot
they rly dont check that when they do an inspection lol. i dont even think a speedo is required by law.
Old Oct 14, 2009 | 08:08 PM
danomatic93's Avatar
June 2010 ROTM
If CEL is on, check the CEL FIRST!! (CEL = Check Engine Light)
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
Old Oct 14, 2009 | 08:44 PM
sounds to me because ive had this problem
1: bad speed sensor on trans
2: bad speed sensor connector plug
gfield13
Feb 19, 2008 11:02 AM
classic97
Feb 9, 2008 03:43 AM
pjperez64
Aug 6, 2007 09:03 AM
rdas45
Mar 2, 2007 08:03 AM
chrisroug
Oct 2, 2006 11:36 AM
