Traction bars & Short shifter
Old May 4, 2007 | 12:53 PM
Honda mp's Avatar
Default Traction bars & Short shifter
I would like to put traction Bars and a short shifter. is there a lot of work for traction bars. do you have to lift the motor or any thing like that. I would think the short shifter wouldnt be very diffucult.
Old May 4, 2007 | 02:03 PM
Default RE: Traction bars & Short shifter
Short shifter is really straight forward actually, I think theres a DIY here in the DIY section. Or run a search.
What kind of traction bars are you talking about? Like strut/tie bars, sway bars, torque dampers, etc..
Old May 4, 2007 | 02:29 PM
Honda mp's Avatar
Its got sway bars. But in having a problem with it wheel hopping. I was also thinking it might be the rims and low profile tires? Would the Torque Dampers help with that?
Old May 4, 2007 | 03:07 PM
Yeah torque dampers will definitely help. I'd swap out the motormounts first though.
Old May 4, 2007 | 08:22 PM
BlackDX's Avatar
(avid racings torque bar for an 88-91)
Traction bars are set up to bolt to the frame around the radiator and they have bars that go to either lower front control arm. They are ment to keep the arm from flexing rear wards and lowering if not removing wheel hop.
There are several units available.... choosing one is hard (I've been debating this as well) and also price is a factor. I'd do research on the various makers and see which comes up best in your eyes.
Old May 4, 2007 | 08:26 PM
FlipHKD720's Avatar
https://www.hondacivicforum.com/m_225967/tm.htm
found it for ya
Old May 4, 2007 | 08:30 PM
cyberx32's Avatar
Talking about wheel hop, i get it when i dont rev too high and i let the clutch out, but if i rev it good and let the clutch out i do a nice burnout, is that a bad thing that it hops when im not revving too high?
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
icwicked
Jan 19, 2008 10:37 PM
mybrokenblinker
18
Mar 19, 2007 02:34 AM
CSaddict
Nov 1, 2005 03:33 AM
05CivicLX
Jun 4, 2005 12:46 PM
