warning sounds
Old Dec 22, 2007 | 08:36 AM
redheadwaitress's Avatar
Default warning sounds
Hi everyone I'm new to this.My question is when I leave my lights on or the key in the ignition and open the car door,a warning use to go off letting me know.Now it does'nt.I checked the fuses and they are ok.What do I need to do to rectify this problem short of taking it back to the dealer?
Old Dec 22, 2007 | 09:25 AM
Default RE: warning sounds
does the dome light turn on when you open the door? (assuming the dome light switch is in the correct position)
if it doesn't, the door sensor may be broken. This happened to me and i didn't feel like buying a new one so I took mine off of the rear door. The door sensor is located in the door jam, and it will look like a switch kinda. When you close the door it will press the switch, turning the light off and making the warning sound for the ignition stop. When you open the door, the switch turns the dome light on and warning signal for the ignition.
The door sensor should be really simple to switch out for a new one. Mine had one screw and a female quick disconnect plugged into it for wiring.
To get a new one you can search on eBay for used ones, go to a junkyard, or you may have to go to the dealer (it's not an expensive part)
Old Dec 25, 2007 | 06:21 PM
Actually what's going on with my car is when the headlights are left on I know longer get warning signal even when my key is left in the ignition.All of those things use to warn me but not anymore.Is there any help for this?
Old Dec 25, 2007 | 06:27 PM
i have no clue about the headlight warning sound, i don't have one
Old Dec 26, 2007 | 08:07 AM
The older models did not have a headlight warning. Since yours did before (and like trustdestruction suggests, the door switch is OK) you probably need to replace the beeper module itself, under the dash.
There is also a switch which it's only purpose is to detect if the key is in the ignition and activate the beeper, that can go bad.
swizz977
Mar 26, 2006 09:06 PM
boatboatboat
Feb 1, 2006 10:15 PM
Belmont
Aug 2, 2005 02:37 PM
xe1002
Jul 10, 2005 11:13 PM
Super Mario
May 2, 2005 12:50 AM
