00 civic air intake removal
Old Jan 24, 2010 | 09:27 AM
sifiwiz's Avatar
Default 00 civic air intake removal
I'm trying to put a cold air intake into my 00 honda civic ex. How do I remove the stock air intake? I wanna try to avoid removing the bumper or the splash guard. thanks
Old Jan 24, 2010 | 07:12 PM
croninc's Avatar
You have to remove the bumper, there is also a DIY for this install. Try using the search button it should come up.
Old Jan 25, 2010 | 07:19 PM
conceptualpolymer's Avatar
My sig contains a DIY for a 97 CX. Check it out; it may help.
Old Jan 26, 2010 | 05:42 AM
norbster86's Avatar
Hack saw and keeping part of it in the bumper worked for me. One day I'll get around to removing it entirely.
Old Jan 26, 2010 | 06:50 PM
Scott53092's Avatar
^ Hacksaw?! Wow, completely unnecesary. Removing the stock intake is a s simple as removing the plastic piping from the throttle body and following the intake piping down to where the filter box is. There will be screws holding it to the firewall and then it should all just pull off. If you run a short ram you technically can leave the intake piece that is in the bottom of the bumper, but it is unneccesary and looks bad. So for that take your bumpr off, I think there's a few screws, and just pull it out. You can have the whole stock removed and the new put on (reinstall is super easy, it's taking stock out that's time consuming) in under 30 minutes if you can take your bumper off quick.
Old Jan 27, 2010 | 05:32 AM
norbster86's Avatar
The pipe that comes up from the bumper and goes into the stock air cleaner box is what I hacked off.
It was getting in the way when I swapped motors and was more of a stress reliever than anything
Old Jan 27, 2010 | 06:18 AM
Dam that is insanely ghetto norb.
https://www.hondacivicforum.com/foru...ad.php?t=69748
Old Jan 27, 2010 | 06:28 AM
norbster86's Avatar
When I get a new front bumper cover I'll remove it the proper way. Does that work?
strtballer98
May 20, 2007 08:39 PM
Method
Sep 9, 2006 10:24 PM
ptw711
Aug 12, 2006 10:56 PM
Bostonhoodhop
Aug 1, 2006 08:57 AM
Technician
Oct 12, 2005 09:23 AM
