98 lx headers
Old Sep 19, 2005 | 03:47 PM
mynmisoli's Avatar
Default 98 lx headers
My stock manifold is cracked so instead of buying a new one for 500 bucks from the factory, I'd rather upgrade to cheaper headers. What should I get? Keep in mind that tthe car still needs to pass SMOG and is my daily driver. Thanks
Old Sep 19, 2005 | 05:29 PM
Clean98EX's Avatar
Default RE: 98 lx headers
You know, you could run an entire EX exhaust. From the header back. With a new header, cat and cat-back exhaust, it would pass emissions testing and you could probably do it for around 500 bucks. Headers for lx models can be hard to find, but EX stuff is REALLY easy. Just an idea, hope it works out.
Old Sep 19, 2005 | 05:51 PM
mynmisoli's Avatar
I dun't know how that would work. Are you saying get an LX header for an EX exhaust? Get an EX header set for an EX exhaust? Sounds like it wouldn't work.
Old Sep 19, 2005 | 06:24 PM
Clean98EX's Avatar
No, you could run a COMPLETE EX exhaust. because the cat on an lx is in a different place than on an EX. If you had 500 bucks, you good get an EX header, cat (stock even), and a catback exhaust. the only thing that could be a problem is the o2 sensor on the cat. the wires mite not make it to the new cat. The piping would work though. Is it a coupe or a sedan?
Old Sep 19, 2005 | 06:28 PM
mynmisoli's Avatar
98 lx, 4 door sedan I believe. So I can get headers and an exhaust designed for an EX and put it on an LX? That just doesn't make sense because every product for the two always make different models for each car.
Old Sep 19, 2005 | 06:36 PM
Clean98EX's Avatar
They do that because of the cat location. but with the new cat location it wouldn't be a problem.
Old Sep 19, 2005 | 06:43 PM
mynmisoli's Avatar
is the length of the ex be shorter than the lx since the lx is a 4 door? are ou saying it wouldnt have any problems with the positioning? theres alot of stuff to take into consideration.
Old Sep 19, 2005 | 06:45 PM
Clean98EX's Avatar
EX's were made in sedans
Old Sep 19, 2005 | 08:36 PM
mynmisoli's Avatar
OK, so say id i get.......DC headers made for the EX and find a stock ex exhaust, I should have no problems with the installation and the emissions?
Old Sep 19, 2005 | 09:28 PM
Nail I3unny's Avatar
ORIGINAL: Clean98EX
wrong. EX's are coupes and sedans. then the DX is a stripped EX coupe, the LX is a stripped EX sedan. other than that your right. you could get a full exhaust system and it would work cuz the only difference exhaustwise between the EX and LX/DX is cat placement. so if you get an EX header for your LX sedan...you will have to get an EX exhaust too. and itd be a good idea to replace the cat at the same time.
im not sure if tip placement of the exhaust is different...i dotn think it is tho. but if it IS different, you could also get an EX rear bumper for like 200 bucks (make sure its the same color please ) and slap it on there. then youd be all set.
