Ceramic or steel header?
Old Jun 24, 2007 | 06:56 PM
Anthony's Avatar
Default Ceramic or steel header?
I did some looking around here and there for headers. I know theres two types the steel and the ceramic, but is it really worth it to buy the steel. Price wise they are alot more then the ceramic ones. I heard the ceramic could crack easier from heat. The stock header is made from ceramic?
Thanks.
Old Jun 24, 2007 | 07:01 PM
FlipHKD720's Avatar
Default RE: Ceramic or steel header?
ceramic disappates heat a bit better than the regular stainless steel
Old Jun 24, 2007 | 07:52 PM
Sigracer10's Avatar
like flip said ceramic dissipates the heat better and therefore runs at a cooler temperature. but the stainless steel will run at a higher temperature and will be able to handle higher temperatures than ceramic before failing. I'm not exactly sure how much more but the ceramic will crack before the stainless steel. but also you have to remember that the cracking temperature for either is still very high on a good quality product and would only be reached in extreme situations most common to occur in racing.
Old Jun 25, 2007 | 04:49 AM
cderalow's Avatar
sigh...where to start
1) there's two types of header, streetable (read, emissions friendly) and race style (read, emissions unfriendly)
2) all headers are steel, some happen to be polished steel, preferably stainless, and others are ceramic coated
3) the ceramic coating is designed to help dissipate heat, i won't get into the mechanics of it, because it's a monday morning, and I just plain don't feel like explaining heat transfer
4) as long as it's a quality piece, you shouldn't have to worry about either failing as a result of heat, as quality pieces = designed & researched, and not just some ebay knockoff (this means the company behind it put some thought into how to make their header)
5) the stock header (depending on year/motor etc) is generally made of a mild stainless steel, or cast iron
6) the temperature of your header is not dependent upon material, it's based on your engine. the surface temperature of the exhaust pipe, and the ambient air temperature around it, is dependent upon the coating of your header.
there's 3 concerns really when it comes to headers
1) cost
2) emissions requirements
3) expected results/future plans
cost is easy, how much do you want to spend?
emissions again, easy, do you live in california?
results/plans, do you want to go forced induction (turbo)? are you staying n/a? do you think adding a header will make you into the fastest thing on the street?
Old Jun 25, 2007 | 06:31 AM
my05civic's Avatar
^ well said.
Old Jun 25, 2007 | 07:12 PM
Anthony's Avatar
Thanks, that information was very helpful and detailed. Im not planning to turn the car into a racing car cause of the engine. I think ill go with the ceramic coated headers instead, i live in Georgia. i know not to get them from ebay. Whats the lowest you'll think i can get some good quality ceramic headers. I heard about DC sports, i've seen some around for about $299.
Old Jun 25, 2007 | 08:24 PM
Wheelbroker's Avatar
I just PM'd you Anthony...go read the message
Old Jun 29, 2007 | 06:12 AM
bpapa's Avatar
Member
Can you draw a generalization about which type gets the best hp gains? Or is that more dependant on the actual layout of the pipe? I know many many other factors would be involved when talking about hp gains, but that's why I said 'generalization'.(simply trying to flameproof my post)
Also, I'm better versed in the mechanics and physics of engines than I am in actually working on them or the details, specific parts or brand reputations of many of the aftermarket tuner parts manufacturers. Could someone give me a short-list of 'good' brands that are worth looking at when it comes to headers.
I notice that there is typically a pretty significant variance in price on differingbrands of say headers/exhaust/etc on most parts sites. I remember reading 'you get what you pay for' many times in the new member guide, but I guess I'd just like a place to start.
If you ever feel like explaining it I'd love the opportunity to read it...
Thanks for any help!
Old Jun 29, 2007 | 07:47 AM
my05civic's Avatar
Header (exhaust manifold to be most correct) Manufacturers:
Bisimoto
Hytech
DC Sports
Megan Racing
Apexi
Greddy
Comptech
Hedman
HP Racing
Holly
Pacesetter
Kamikaze
Ractive
Ebay generics
Edelbrock
Landspeed Racing
Spoon
Stillen
Old Jun 30, 2007 | 06:48 AM
Nail I3unny's Avatar
Unless you are already pushing 600+ horsepower...the differences between ceramic/stainless and 4-2-1/4-1are virtually none.
skitza_the_Si_kid
Mar 19, 2010 02:36 PM
Dan Sama
Aug 1, 2006 07:53 AM
fast93civic
Mar 18, 2006 01:54 PM
plc00133777
Nov 2, 2005 09:38 PM
D16z6
Dec 21, 2004 09:04 PM
