D16Y7 Exhaust Manifold Compatibility
Hey guys...I found out my exhaust manifold has the dreaded "crack" at the Y intersection. I can smell exhaust fumes inside the car when the windows are up..I'm assuming this is part of the reason. The previous owner tried to weld it back closed, and it semi-worked. I also have a bolt broken off into the manifold, so only one bolt is holding the heat shield on currently.
Anyways, on to my question: what other exhaust manifolds are the same as the one I have now? I have a D16Y7 motor ... 1.6L non-VTEC, on a 1997 Civic LX. I was told I'd have to find a 96-98 Civic DX or LX and these should work? My exhaust manifold and catalytic converter seem to be one piece. I'm going to be calling some people on Craigslist to see if they have the manifold and it'd sure save some time to know the vehicles that would be compatible. Thanks for any help!
Thank you! I was debating whether or not I should try to find one used, or if I should bite the bullet and buy one online for $200-$300. In my county, I have to pass emissions yearly. I was thinking that since the catalytic converter AND the exhaust manifold are in one piece...wouldn't it be high-risk to buy one used, knowing that either the crack could occur or the filter could be bad/go bad? What do you think?
100% of those style manifolds will crack down the middle. There's really nothing you can do but buy one and hope for the best. But that gives you the opportunity to take your old one to a shop and have it welded properly so it'll be ready in the future.
just a question... i need clarification.
I was told even the EX manifold would fit on a y7 but you need the down pipe and cat with the manifold because of the y7 having the cat attached to the manifold.
Please correct me if im mistaken. Just trying to learn.
Edit... Found this while searching HCF, it was a sticky already, might help you out KoKo4, i know i learned from it.
https://www.hondacivicforum.com/foru...version-73237/
Last edited by JWilli97EKlx; Oct 29, 2012 at 10:55 AM. Reason: found new information and wanted to add a link to it.
If you have a USDM EX manifold, then yes, you would need the header, downpipe, and cat, plus some modification to the rest of the exhaust. Because the catalytic converter is separate and twice the size of the DX cat, you would have to have a shop cut some of the pipe off and weld the pipe to make it fit. You would also need O2 sensor extension wires. (Better to buy actual extension harnesses than to splice wires.)
A CDM Civic EX = USDM Si, which would have a different engine. (B series versus D series.)
Thanks guys. I ended up finding a replacement exhaust manifold / CAT combo for $170 shipped on eBay. I installed it and it works fine! Had to make the three holes that attach to the rest of the exhaust SLIGHTLY bigger, but other than that, it was a direct fit!
Actually, if we're talking EK here, it's the CDM Civic SiR that has the B. The Civic EX is a 4 door with a Y8.
