Evo2
I think you mean models.. your generation (99-00) are sought after, it's just that you got an LX model.
it is my understanding, from both a honda dealer and an autoshop that the lx has the same exhaust layout as the dx. assuming that if they offer an exhaust in 2/4dr for the dx, it should also work for an lx even if i got one that was labeled only for a 2dr dx. was i misinformed again? cuz thats how ive been searching for exhausts is through the dx
really..... once again i was ill informed by someone else, they had said my gen was basically kind of a mistake or the not so great years for the civic.
Quesiton: Do you plan on ever buying a header for you civic? or putting on a Vtec head?
You own an EG and not an EK.. Off the top of my head I wouldn't know. Give me abit when I'm off work.
when i search for LX pretty much nothing comes up except cheezy brands or not loud enough ones.
i actually wasn't ever planning on buying a header because of what i was informed like i stated above. i pretty much jus wanted to put an intake (done), exhaust, and possibly new lights and wheels. thats all i really intended on doing.... i know im not a "real tuner", but that's just me.
it was actually someone from this forum that had told me all those things, although, i dont remember who it was exactly.
. I was only suggesting an EX conversion because if you wanted a header after buying a LX or DX exhaust will require some fabrication later on.
Magnaflow... http://www.magnaflow.com/02product/d...rtnumber=15642 and if you get it thru autoanything.com its $392.71 shipped to your house ive got it http://www.autoanything.com/exhausts....aspx?kc=ffsku
You only need to convert to EX exhaust if you want a header (or turbo). There is no other reason to.
If he buys a test pipe now to fill in the gap created by using an EX exhaust, then later if he wants a header he just has to replace the test pipe section with a cat. Makes it perfectly simple.
But if you but a system for an EX/Si, it will fit, all the bends are the same. it will just come up short, the test pipe in NO WAY replaces teh cat, it simply works like an extra length of pipe.
As far as how difficult the swap is...not very, if you know how to do basic mechanical work. The trick to it is preparation. The night before I did it I sprayed all the nuts I was going to be removing with penetrating fluid and put it up on jack stands. Son in the morning I just had to get up, crawl under the car and undo the now very easily turned nuts.
Also make sure you have enough hardware to connect everything. Otherwise you will be like me and have to run out and get parts which can take 15 min to an hour.
Time wise I spent 4 hours and that was with some un-cooperative nuts and taking my time/being paranoid.
Hope this helps.
thanks for all the input everyone, but i actually received an email yesterday from a website that had 1 evo2 in stock! so i jumped on it right away and placed the order around 12:30 this morning haha. and it only cost me less than $30 more than i was searching for. a small price to pay for what i want, especially since it is a discontinued item. so hopefully by this weekend if not early next weekend i'll have it installed and some pics up for everyone. of course, thats if my order actually gets the last one in stock haha.........
