Which header fellas?
Old Jan 25, 2005 | 07:44 PM
fast93civic's Avatar
Default Which header fellas?
Currently I have a Ractive 2 piece header on my 93', and I don't know if I should replace it with a DC, or keep this one. I looked on the net for these Ractive headers and they're pretty expensive like $229 for what I have. So basically does this one even compare to a DC, or should I replace it?
Andrey
Old Jan 25, 2005 | 08:57 PM
sacicons's Avatar
Default RE: Which header fellas?
DC sports is way better than Ractive.
Old Jan 25, 2005 | 09:46 PM
Grim's Avatar
IT depends on your goals. I can tell you that switching between the two will probably not net you a noticible gain in power, even if the DC is well designed. I guess it depends on your budget, and whether or not you want to squeeze every last bit of power out of your motor in current form. I would say keep your current header and replace and upgrade if it were to crack.
Old Jan 26, 2005 | 12:10 AM
sacicons's Avatar
with the mod list you have planned, every bit of backpressure you get from an inferior header will cost you power. it probably wont be noticeable now, but after all the other plans come to fruition, get a new header. but yeah, i didnt read the part about you already having the Ractive, so keep it for now, its not worth spending the money to replace it instead of a whole new mod. and though ractive cant compare to DC, its not too bad for the cheaper headers.
Old Jan 26, 2005 | 02:04 PM
exactly what i had planned, thanks sacicons.
Old Jan 28, 2005 | 05:02 AM
blackeyes's Avatar
replace it. i have a lonely dc 4-1 one peice waiting for a new home.
Old Jan 28, 2005 | 07:44 PM
thanks for the offfer bro, but I got my self a dreded auto here, and a DC 4-1 wont fit nothing but a 5 speed.
Old Jan 28, 2005 | 08:16 PM
D16z6's Avatar
Why dont it fit a auto??? auto and 5spd are pretty much the same right???
Old Jan 29, 2005 | 08:14 PM
No, auto is bigger than a 5 speed, and this DC 4-1 isn't the only part that won't work, AEM V2 also wont' fit.
Old Jan 30, 2005 | 02:11 PM
blackeyes's Avatar
i had a dc header on my first dx auto (it was a 4-2-1). i would have put in on the one i have now but the car came with one.
Evoman
May 18, 2009 07:02 AM
branx
Mar 24, 2008 04:32 PM
jeff_o
Jan 10, 2008 01:08 AM
darknightmr2
Jan 23, 2007 01:02 AM
nate081304
Jan 16, 2007 07:41 PM
