Headers & check engine light question??
Old Oct 2, 2006 | 10:29 AM
telecasteriv's Avatar
Default Headers & check engine light question??
I have a 2000 Civic w/ 1.6L engine, installed new Aerospeed headers and check engine light is one. I have an O2 Sensor Simulator & Heater Sensor Simulator from www.02simulator.com. My mechanic removed the secondary O2 sensor, installed O2 sim and light still on. Code says P0141 heater sensor.
Is there a way to "trick" the ECM with the O2 sim without having the secondary O2 sensor hooked up, or do I need to re-install the secondary O2 sensor??
Steve
Ferndale, MI
Old Oct 2, 2006 | 12:47 PM
Remmy's Avatar
Default RE: Headers & check engine light question??
That is the right spot for the sensor... however I have a question for you. Is the sensor cut and spliced in? Basically, did the mech cut the OEM o2 sensor wire to splice in the simulator?
Old Oct 2, 2006 | 01:23 PM
The first O2 sensor is attached to the headers (front of car), and the O2 simulator is spliced in, so O2 sensor is not removed.
The secondary O2 sensor has been completely removed.
Old Oct 2, 2006 | 01:51 PM
Remmy's Avatar
Ok, wait wait.... is the simulator connected where the 2nd one was supposed to be?
Old Oct 2, 2006 | 02:22 PM
No, the simulator is spliced into the first O2 sensor which is still on the car. There's nothing connected to where the secondary O2 sensor was.
Old Oct 2, 2006 | 05:55 PM
Remmy's Avatar
the simulator needs to be on the 2nd sensor. It cannot be cut and then spliced with the simulator. You need to shave the wire then attach it
Old Feb 9, 2008 | 08:27 PM
Big C's Avatar
where can i get this simulator?
Old Feb 9, 2008 | 09:36 PM
FlipHKD720's Avatar
Ebay or www.o2simulator.com
98blackcoupe
Dec 11, 2013 08:04 PM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
blatin
Jun 3, 2007 12:31 AM
Imari007
Mar 18, 2007 09:58 PM
