Installed headers, now Check Engine Light is on.
Old Jun 2, 2007 | 11:56 PM
blatin's Avatar
Default Installed headers, now Check Engine Light is on.
I have an 01 civic dx.Yesterday i installed new headers. I drove the car around and everything was fine. Then today as i was getting on the freeway, my CEL came on and is still on. Im pretty sure that it is because i dont have a catalytic converter anymore. The headers came with a plug foran o2 sensor. I just put both o2 sensors in anyways. My friend told me that the CEL came on cause of emmisions. If I just plug the second o2 sensor, will the CEL turn off? or does this have nothing to do with emmisions and i could be looking at a bigger problem??
Old Jun 3, 2007 | 12:11 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: Installed headers, now Check Engine Light is on.
pull the CEL code and make sure it's a O2 sensor error code. You should have re-installed both O2 sensors.
Old Jun 3, 2007 | 12:16 AM
blatin's Avatar
I believe that Auto Zone will tell you the error code for free. But i want to know if i can fix it myself before going there. Also, is it true that your car performs worse when the CEL is on?
Old Jun 3, 2007 | 12:31 AM
June 2010 ROTM
well, depends, you should never ignore a CEL. If the CEL is because it isn't reading a O2 level, then the car will assume a default level and run from that. So it could run very bad. Just go to Autozone, why waste time? Just get the code and go from there.
98blackcoupe
Dec 11, 2013 08:04 PM
telecasteriv
Feb 9, 2008 09:36 PM
Imari007
Mar 18, 2007 09:58 PM
Scroder
Sep 7, 2006 02:49 AM
curlybandit
Jul 5, 2006 08:45 AM
