I want an exhaust that wont rust in 1 yr
ORIGINAL: addiction2bass
you spray your pipes with WD40...... that really doesnt help any.LOL gets burned/washed right off....
enigma 34 What you need to do is ceramic coat your exhaustto avoid rusting , you can coat the outide for anti rust and inside for smooth flow and temprature reduction tofind more info go onto wwwpowerkote.co.za
your pipes might not feel hot but really... have you ever touched your muffler case or exaust pipe after youve been driving for 1/2hour? its pretty warm. you can do what you want with WD40 but take it or leave it... its not gonna extend the life of your pipes hardly any if any at all!
remember pipes have 2 sides of steel. inside and outside. moisture inside the pipes can rust out the pipes from the inside out just as easy as outside in.....
if ya dont believe me then take off your exaust pipe off the front and run a garden hose water thru the pipes and watch all the brown rust colored water come out the other end
your best bet for LONGEST LIFE would be stainless steel and a nice brand so the quality in the stainless steel is there not just one of those RIP OFF EBAY pipes...
spend the good money on a set of pipes one time and it should outlast the car as long as its not damaged.
Just a followup for anyone searching, I found that the hole in the system was isolated to the muffler section. So ordered up a new Honda muffler and a bunch of the hardware online at www.hondaautomotiveparts.com. Sprayed the B-pipe to Muffler bolts with PB blaster and let it sit the night, then unbolted the old and put the new section in. No cutting, welding or anything drastic required. The rubber mounts came off easily with a squirt of WD-40. Actually, the most difficult part was putting the new donut gasket on the end of the existing B-pipe. If there was some sort of trick to doing this, I didn't know it. Even got a new Honad end finisher piece that bolted right to the end pipe. I think it looks nicer than a fart can.
Hopefully that section lasts as long as the original! For $140 including shipping, it wasn't a bad deal at all.
Hailchristian
Apr 14, 2008 03:12 PM
civicblend97
Feb 16, 2008 08:27 AM
FRESH96
Dec 12, 2007 09:18 AM
