Megan or DC sports headers?
so now i get to get the universal O2 sensor simulator, and a high flow cat, should i get the Magnaflow univeral highflow cat or the one built of the EX.....Will the simulator killmy gas mileage?
No, the after cat O2 sensor does not change a/f ratios. It is completely passive and the only thing it does is throw your check engine light if your cat is not working correctly. It has no active function.
Hey tknaub... I am doing the write up on the Thunder header I got from westimports... I dont know about the other guys but this thing is amazing... I did the whole LX---->EX conversion and it turned out fantastic...
Here is a sneak peek!
NICE
I am also doing the LX to Ex convertion......so far i got headers, catback, cat converter, and O2 simulator......now i think i have everything, Is that what you needed?
You doing it yourself or bringing it to a shop? If your doing it yourself you'll need the right tools. 3/8" ratchet set, you will be using primarily a 12mm socket, and the 14mm sometimes. rust removeing spray, I recommend pb blaster, a breaker bar, rubber mallet, maybe even ano2 sensor socket( can be removed without one but if your worried about rounding off the edges or tightening to spec might consider it). I also recommend following a manual or aDIY, I used this one to do my megan racing header swap http://honda-tech.com/zerothread?id=1113916Thats for a 6th gen civic though and the converter is seperate from the manifold but it might help for some things.
This may sound really stupid but......Theexhaust has2.5" piping with 2.25" inlet and the header has a 2.25" outlet so will my 2.25" catalic converter work or do i need the 2.5"?????[&:]
Civic Si 00
Mar 15, 2008 01:06 AM
joostan
May 3, 2006 02:56 PM
alone plus she knows i would probly runinto a problem, this is my first car i have ever modded.
