O2 sensor/ cat. converter
Old May 18, 2008 | 10:15 PM
Inev's Avatar
Default O2 sensor/ cat. converter
Hey guys...
Its been awhile since I last posted but i'm just getting back into my honda..
Got my license about a month ago, and my moms been driving my car back and to work.
But anyway..
Last June I had a Catalytic Converter installed. Since then, had no problems.. cept a rear main seal oil leak, but thats irrelevant. Tuesday of last week, I had a Check Engine Light come on. I took it to my mechanic on wednesday and the code was pulled. 420, Cat going bad.
So I thought that was kinda wierd, just got it 10 months prior, so I had it diagnostic'd and they said cat was going bad, and an O2 sensor was bad.
Wouldn't I get a CEL if the o2 sensor was bad, or going bad?
And where would I be able to get one?
Old May 19, 2008 | 03:57 PM
Default RE: O2 sensor/ cat. converter
The O2 sensor may be fine but there is a leak in the exhaust manifold. In this case, the O2 sensor would erroneously signal the ECU to increase the amount of fuel in the cylinder, and this rich condition would destroy the catalytic converter.
Alternatively, in some cases, a faulty O2 sensor is not recognized by the CEL/ECU system.
Old May 21, 2008 | 09:24 AM
point break 92's Avatar
couldn't have said any better, that about sums it all up. yes
Old May 29, 2008 | 02:06 PM
Inev's Avatar
So....
All of a sudden the CEL just goes out.. I don't have a Check engine light anymore.. Why would it all of a sudden turn off?
Like I said, code was pulled and the cat was under threshold, and now a week or so later, it turns off.. ?
Old May 29, 2008 | 02:22 PM
Well, just clear the code from the ECU and hope the CEL doesn't return. If it does, pull the code again to verify that it is the same one as earlier. Sometimes problems are intermittent.
The MH
Jun 30, 2010 04:27 AM
mr honda
Feb 25, 2008 05:49 PM
Remmy
Jan 23, 2005 01:16 AM
fast93civic
Jan 5, 2005 11:05 AM
