oxygen sensor
Old Sep 28, 2007 | 03:48 PM
cmansmith19's Avatar
Default oxygen sensor
is there such a thing that i can plug into where my oxygen sensor is suposed to go and it will tell my car everything is ok
Old Sep 28, 2007 | 03:51 PM
my05civic's Avatar
Default RE: oxygen sensor
do you have a CEL or something?
Old Sep 28, 2007 | 03:59 PM
yes and it is for alot of reasons all of which i dont have the money to fix rite now. not only do i not have the money to fix them but by the time i am thru i might as well just do a swap rite now i have no v tech and i want a v tech
Old Sep 28, 2007 | 04:02 PM
FlipHKD720's Avatar
www.o2simulator.com, should work, did for me
Old Sep 28, 2007 | 05:12 PM
my05civic's Avatar
vtec, not vtech. vtech is a phone company... anyways, vtec isn't all that impressive on a NA civic...
Old Sep 29, 2007 | 01:45 PM
warner_ro's Avatar
here is what i did.
1. get a dorman spark plug non-fouler (18mm) size would fit a older ford truck. there about $5, and has 2 in each box. (advanced auto parts, and auto zone have them)
2. then drill a 1/2 inch hole in one of the non-foulers,
3. then screw in your secondary O2 sensor into the 1/2" drilled non-fouler.
4.take the undrilled spark plug non-fouler, and screw it onto the bottom of the drilled fouler
5.then screw in the O2 sensor into the drilled one.
6. once you have your 02 sensor installed again using both non-foulers, unplug your negative side of the battery for about 1 min.
7. reconnect your battery and your good to go.
this will make it so the CEL will not turn on for your o2 sensor, but it will still let you know if something else is wrong. this really works and it the best thing to do. costs $5 and take about 15 minutes.
Old Oct 2, 2007 | 04:18 PM
yeah that would work great if my car wasn't a huge piece of crap that barely runs with a 193000 miles of me driving it like i stole it
j_fukin_t
Oct 3, 2005 10:22 PM
Traumagas
Sep 28, 2005 11:20 PM
Traumagas
Sep 24, 2005 05:31 PM
Uncle George
Aug 11, 2005 08:55 PM
rzimmer11
Mar 19, 2005 11:40 AM
