What else should i get b4 the turbo?
Old Aug 9, 2007 | 01:32 AM
IcEman_si's Avatar
Default What else should i get b4 the turbo?
alright so i have an 07 si...so far i've put...
aem cai
2 turbonators? funny right...
skunk2 catback exaust 60mm...what should i get b4 turbo
Old Aug 9, 2007 | 01:52 AM
that_guy5's Avatar
Default RE: What else should i get b4 the turbo?
lower it??
Old Aug 9, 2007 | 05:29 AM
my05civic's Avatar
ORIGINAL: IcEman_si
aem cai
when do you plan to turbo? how much do you want to boost? do you realize that you void your warranty if you turbo? when you turbo, your CAI will not be used (so you will have wasted money on it). also, i hope the turbonator you speak of isn't this:
This is as useless as a performance chip on ebay...
Anyways, do your research before you turbo. Are you planning to do it yourself? Boost is not as easy as everyone makes it seems. I'm not sure how rigorious the new SIs are, but you might want to consider building the internals first so you can run more boost in the long run.
Also, i'm not sure what size the exhaust translates to in inches--i'm too lazy to convert--but you'll need 2.75"-3.00" piping. I'll guesstimating, but i think 60 mm is like 2.3ish so you'll definitely need to upgrade there. the muffler itself should be okay though
Old Aug 9, 2007 | 04:26 PM
Motor35's Avatar
You should upgrade your clutch. And are you serious about the turbonator?!?! That crap doesn't work. And 05 has great advice here! Good luck
Old Aug 9, 2007 | 05:04 PM
polo708's Avatar
actually the spinning motion of intake air does show a gain in hp and mpg. Problem is that most companies dont make them properly and it just acts as an obstruction in your intake. Above is some good advice... you wont need your intake anymore and the biggest thing you can upgrade prior to your turbo is the suspension. All that power is useless if you cant get it all to the ground.
Sell the cold air, trash the turbonator and get some springs/coilovers and sway bars. Also, a cheap upgrade if you can do it yourself is some poly bushings and motor mounts(if you have a manual tranny). As for exhaust... 3", no way. 2.25"-2.5" is ideal, even for boost. Make sure the exhaust diameter is the same from the exhaust manifold all the way back. It will make a hige difference.
Old Aug 9, 2007 | 09:53 PM
IcEman_si's Avatar
so if my cold air is going to be useless then do i just put my stock one back on or wtf? what kind of suspension should i get?
Old Aug 10, 2007 | 03:03 PM
polo708's Avatar
the turbo kit should come with an intake piping and fitler of its own. The CAI wont fit because its designed to be installed at the stock throttlebody location. With a turbo kit the intake point is changed making your CAI useless.
mikeybson
Apr 24, 2010 02:28 AM
gokudo_sama
Mar 26, 2008 03:32 AM
blackmetal619
Mar 22, 2007 06:10 AM
pimpingitup239
13
Jul 7, 2005 07:48 AM
hisokano1
Apr 3, 2005 08:30 PM
