ws2 and hi flow cat
Old Mar 6, 2007 | 09:18 PM
mybrokenblinker's Avatar
Default ws2 and hi flow cat
So i'm about to order an O2 simulator, a hi-flow cat from magnaflow, and a ws2 exhaust. My main question is what is the diameter of the hiflow cat and if it is different than the ws2(which i think is like 2.3 inches) how do they join? would they come with all the things i need? If it has any effect, I have a dc 421 header as well.
Old Mar 7, 2007 | 07:36 AM
FlipHKD720's Avatar
Default RE: ws2 and hi flow cat
does the cat bolt on or is it open-ended so it can be welded into your exhaust system? If its bolt on, it will PROBABLY bolt right up the header, but if not you can always weld a custom flange on tehre so that it bolts right up. As far as different diameters go, a muffler shop can custom bend a pipe to fit the diameter you need. Hopefuly the cat is bigger than the catback, that way it wont be restrictive.
dulas101
May 14, 2008 01:09 PM
Eun
Mar 22, 2007 05:15 PM
jjouet
May 22, 2006 05:07 PM
jusplayn85
Feb 24, 2006 08:17 PM
fastman90
Jan 8, 2006 09:52 PM
