'99 CX grille replacement
Old Aug 7, 2008 | 12:13 PM
mrkerb's Avatar
Default '99 CX grille replacement
Hi, my grille is faded and I want to change it out. It looks like plastic fasteners retain the top and screws at the bottom. Access for the bottom screws looks pretty tight, do I need to remove the bumper cover or ?
Any advice from someone who has been there before would be great!
Old Aug 7, 2008 | 12:34 PM
ShaTownCivic's Avatar
You don't have to remove the bumper cover. You can just unscrew it once you take the plastic pin things out.
Old Aug 8, 2008 | 07:40 AM
mrkerb's Avatar
Thanks for the reply. I removed the black plastic pins across the top on the grille surround. I can now pull this surround up enough to access the phillips head screws that are now exposed. But... there are also a few screws that attach the bottom of the grille through the "feet" of the grille. The clearance underneath is tight. Any tricks for this part?
teamwhiplash09
Dec 4, 2008 12:29 PM
Dunsy
Apr 13, 2005 10:18 AM
carjohnchen
Apr 9, 2005 11:32 PM
2000Si
Aug 24, 2004 12:02 AM
hondaholic9
Jun 22, 2004 01:30 PM
