Fog Light Install Help
Old Jun 24, 2010 | 11:24 AM
99lx's Avatar
Default Fog Light Install Help
I have the amber ebay fogs, I guess the depo fogs. I'm up to step 33 on the .pdf installation document where it says "plug the harness into the blue-taped connector at the rear of the fuse box". Ok I did that, but now I have two male brown connectors just hanging there, with nothing to plug them into. I'm so confused...again, I have two male brown connectors, with no mention of them in the .pdf directions. Can anyone help me out?
Old Jun 24, 2010 | 02:22 PM
I believe my old DIY thread will help you. Read it in its entirety first. See if it completely applies.
https://www.hondacivicforum.com/foru...ad.php?t=68753
Old Jun 24, 2010 | 03:30 PM
99lx's Avatar
That's exactly what I needed thanks alot.
Old Jun 25, 2010 | 08:55 AM
99lx's Avatar
Another question: Did you have any trouble connecting the brown power connectors to the fusebox? Because I'm trying to click the connectors into their respective slots, and they won't click into place no matter how hard I try. They just fall out of the socket.
Old Jun 25, 2010 | 10:41 AM
croninc's Avatar
Have you tried holding them in the slots and seeing if everything works? If everything works you could use a little bit of tape to hold the connectors in. Are you sure you putting them in the right place, if they dont fit somewhere you can always just tap into another source for your power like your headlights because you only turn ur fogs on usually lol with your headlights.
Old Jun 25, 2010 | 02:11 PM
They're supposed to click into place. If you don't feel the click, press harder. If that doesn't work, its upside down...
Old Jun 26, 2010 | 02:19 PM
99lx's Avatar
Ok, got it and the foglights work great. Turns out you were right about PUSH HARDER. I had to push so hard on those connectors that it ripped off some skin on my thumb, lol.
Old Jul 13, 2010 | 06:25 PM
MrFirewolf1000's Avatar
Default Question on brown plug that comes from the fog lights
Ok i have figured out the whole harness thing. I am not sure where to plug in the brown wire that comes directly from the fog lights. Its got a blue ground cable I am assuming with it. If someone could help me out on where to plug that in. Ive got a car show/ cruise tomorrow night and was hoping to have them working by then. So if someone could help me out quick id much appreciate it.
alanking80
May 24, 2012 09:22 AM
thebadgator87
Aug 18, 2009 12:52 PM
taoksa11
Apr 15, 2008 08:57 PM
bigfank3
Jun 30, 2007 06:59 AM
emooheo
Sep 4, 2006 01:03 PM
