Gauge Cluster
Old Apr 15, 2008 | 06:53 PM
DP_13's Avatar
Default Gauge Cluster
I was just wondering if you could take the gauge cluster outta a 96-00 ex with the tach and put it in the dx without a tach. or ne other suggestions would be appreciated
Old Apr 15, 2008 | 07:18 PM
FlipHKD720's Avatar
Default RE: Gauge Cluster
yup, remove the old cluster and the new cluster will plug right in. The DX cluster has a tach wire behind the engine temp. gauge, it just doesn't get used because the DX cluster doesn't have a tach. Any 96-00 cluster is interchangable.
Old Apr 16, 2008 | 05:19 AM
basbal123's Avatar
^^ yup thats what i did
Old Apr 19, 2008 | 05:35 PM
DP_13's Avatar
Hey guys thanks alot appreciate the info
Old Apr 20, 2008 | 02:54 PM
rs634158's Avatar
i've done the same thing, you can find gauge clusters on ebay or try craigslist.com they go for about $100. Also keep in mind that the odometer will read whatever the new gauges say so keep that in mind when shopping around.
Old Apr 20, 2008 | 05:36 PM
ORIGINAL: rs634158
DOESNT HAVE TO!!!!!!!!!
you can kep your speedometer! simply remove the front face from the cluster, the clear bezel and the black bezel as well, then there is 4 philips screws BEHIND THE CLUSTER on the circuit board bath right behind the gauge. simply remove those screws and the speedo gauge will come right out of the front and simply screw it back together and pop all the bezels back on. VERY SIMPLE!!!!
https://www.hondacivicforum.com/m_433337/tm.htm
this way you keep your milage TRUE!!!!!
JUST DO NOT REMOVE THOSE SMALL SCREWS ON THE FACE! AND DONT TRY to mess with the milage or the needles! they will break VERY EASILY!
1998wagonhatch
Aug 15, 2005 03:36 PM
millertime17
Jun 26, 2005 09:38 PM
specv1faster
Mar 10, 2005 06:49 AM
StifflersMom
Feb 21, 2005 11:28 PM
Wesley
Oct 12, 2004 02:25 AM
