Gauge Cluster Swap
I like the AP2 better if I had to choose a digital cluster. OP, if you decide to do this, good luck. Everything that has to do with installation of a s2k cluster into a Civic is 100% custom. Nothing will be plug an play.
I actually enjoy seeing that little needle in the speedometer flying around, instead of a digital number flickering and changing every 1/2 sec.
You would need the EGT module from modifry.com, and the speedo healer in addition to the wiring mess. If you don't care about the speedometer being 100% correct, or if you don't care about the water temp gauge not working, then wiring it up to simply turn on should be easy.
I'm not saying that you couldn't make a conversion harness, I'm just saying that using a s2k cluster wouldn't be plug and play......maybe unless he purchased additional things other than just the cluster.
how much? also i would need the vss and stuff too right?
1998wagonhatch
Aug 15, 2005 03:36 PM
