gauges
Old Jan 26, 2005 | 01:31 AM
winka's Avatar
Default gauges
I have a 92-95 civic EX and was looking for a set of stock black gauges. If anyone out there is getting new gauges, I'll buy your stock ones. Let me know Thanks.
Old Jan 26, 2005 | 08:55 AM
Remmy's Avatar
Default RE: gauges
you can score stock gauges dirt cheap off ebay u know. also beware if you are getting another cars guages you are going to be stuck with the other cars mileage.
Old Jan 26, 2005 | 01:33 PM
winka's Avatar
Default RE: gauges
Thats not true. I just want replacement gauges. I dont want the entire cluster. I alread took my cluster apart to install an alum,inum gauge bezel cover. I just need the 3 sections of the spedometer. Just like if ya put on aftermarket gauges, same idea. Thanks though.
Old Jan 26, 2005 | 02:30 PM
Remmy's Avatar
Default RE: gauges
oooo. Well, in that case. I dont know where.
Old Jan 26, 2005 | 03:06 PM
XCM828's Avatar
Default RE: gauges
I think he is talking about the gauge overlay that actually has the numbers and stuff on it. They're on ebay.
Old Jan 26, 2005 | 03:12 PM
Kappa22's Avatar
Default RE: gauges
Guage faces, if you will...
Old Jan 26, 2005 | 08:12 PM
Remmy's Avatar
Default RE: gauges
Oh... yea you can find that snaz on ebay all day. But on mine and others ('99-'00) You cant remove them. The needles are irremovable. Basically you need to get an entirely new gauge cluster if you screw up. Before I installed my guages (which was a worrisome experience) I called the dealer and talked to them about it. I asked incase I screw up can they repair it. They said it would cost a $hit load...even if I found somebody to fix it. But they said something about the ecu not agreeing or something like that... it was awhile ago.
Old Jan 26, 2005 | 09:33 PM
sacicons's Avatar
Default RE: gauges
dont worry about the ecu, and slip the faces over the needles from the side, DONT PULL THEM OFF.
winka
Feb 7, 2005 09:41 AM
lurker
Jan 4, 2005 05:01 AM
dadax2
Oct 22, 2004 09:09 PM
dadax2
Oct 22, 2004 09:08 PM
seigi
Sep 16, 2004 06:18 PM
