HELP, Major Problem for 5th Generation
Old Aug 25, 2007 | 04:12 PM
Safety_Driver's Avatar
Default HELP, Major Problem for 5th Generation
Hello everybody!
My Civic '94(4 door) LX got rust on the fourth quarter, a.k.a. rear fender.
Just above the rear wheel, where the bumper connects to the fender with a screw.
I am planning to repair it, by myself.
I'm gonna sand it furts to try to clean the rust as much as I can.
Then I'm gonna put Bondo(from Pep Boys). Sand it again.
And then pait it with spray paint.
BUT here's the problem.
My paint code on the door says: NH-538-3(which is white)
In Auto Zone they have about 10 different kinds of White spray paint?!?
- pure white
- artic white
- cloud white
- classic white
- light champagne
- real white
and many more ... ?!?
Does somebody know which one match the white stock color?
I cannot buy 10 different whites to see which one match my color?!?
Thanks in advance!
Old Aug 25, 2007 | 04:31 PM
Default RE: HELP, Major Problem for 5th Generation
nh-538 is frost white same as my hatch
Old Aug 25, 2007 | 04:55 PM
So I have to look for Frost White?
The paint brand in Auto Zone is called something like Dupli-Paint.
So I have to look for this name. Are you sure it matches the stock color?
Old Aug 25, 2007 | 04:56 PM
t0wards eternity's Avatar
Bondo over top of rust is just a temporary solution. If you don't totally contain the rust and remove it all it will come back and spread. I'd advise against just sanding it down and putting bondo over top.
Old Aug 25, 2007 | 05:16 PM
I understand, but the previous owner hadrepaired it in some way(probably the same that you said)
and now the rust came back. I don't have profi tool and I know that the best way is to cut the entire piece of metal and have
welded it with new metal, but this is way big job. I cannot do it, and I don't have the money for the labor which will be about $500, if it's not more.
Yes, this is temporary solution, but that'sall I can do.
Old Aug 26, 2007 | 05:07 PM
Zwitter's Avatar
If its temporay then I would not bondo it. Pick up some por 15 to stop the rust then paint it. wont look good but will stop the rust.
apoplectic1
Apr 23, 2010 07:07 AM
n8te81
Jun 30, 2007 04:12 PM
HelpMyHonda
Mar 16, 2007 01:06 AM
TimThein
Dec 13, 2006 11:21 AM
civicexracer
Sep 28, 2005 09:57 PM
