How do you remove the parking brake cover?
Old Aug 8, 2005 | 11:50 AM
Big T's Avatar
Default How do you remove the parking brake cover?
I bought a e-brake cover, but I can't get the old one off. I know someone has to know.
Old Aug 8, 2005 | 12:14 PM
93CivicShaved's Avatar
Default RE: How do you remove the parking brake cover?
hey wassup...the ebrake either twists off and then the cover will come off....or there are some screws in the actual handle somewhere that will take it off...hope that helps
Old Aug 9, 2005 | 05:32 PM
Big T's Avatar
I doesn't seem to screw off. And I don't see any screws or bolts holding it in place. Do I have to remove it from inside the center console?
Old Aug 9, 2005 | 11:27 PM
Omen68's Avatar
The easiest way that I know is to take a knife to the underside and cut away.
Some others have been patient enough to twist it off or hammer slowly.
But if your trashing the rubber anyway, save your sanity and just cut it.
GOOD LUCK!
Old Aug 10, 2005 | 08:53 PM
mill$civic's Avatar
if you want to remove the cover (not the handle) i no on my 2000 it would just slip off right over the handle, you just have to twist it a bit, for the handle iv heard that you have to cut the plastic
Old Aug 14, 2005 | 03:09 AM
babyamber's Avatar
put blocks behind your car first !!!!! then just yank. if your not looking to save the old one have fun. destroy. if you want just the hard plastic than thats not hard. crack it! then pull if off. if you want the soft leather/ plastic that will be really hard. but good luck and dont forget thos blocks. (for the maual transmissions automatics blah they can have park lol)
JasonEJ8
Apr 24, 2016 04:11 AM
babaganoosh
Sep 19, 2013 02:01 PM
fastrecklessracer
Jan 1, 2008 03:11 PM
98GuamDX
Aug 15, 2006 03:09 AM
civicdriver609
Aug 28, 2005 10:44 AM
