painting interior trim
Old Mar 10, 2006 | 01:45 PM
TrAvMaNFTW's Avatar
Default painting interior trim
Yeah i was wondering what kind of paint i need to paint my inside trim and where i can get it. all help is wanted. thnx
LATA!!!!!!!!
Old Mar 10, 2006 | 04:43 PM
xXxHondaBabexXx's Avatar
Default RE: painting interior trim
Really you can use ne kind of paint, like spray paint will work also I airbrushed mine with Car paint and clear coated it!! but you can use nething...
Old Mar 10, 2006 | 05:06 PM
uk civhead's Avatar
Use a high build primer first, try and use a spray paint that is made to go on plastic as it will allow a little flex and stop it peeling off. then plenty of clear coat that is suitible for plastic and build up a good few layers.
Old Mar 10, 2006 | 07:30 PM
absoulute's Avatar
the first step you should do is clean it real good with wax and grease remover. are u taking about the whole interior or just trim pieces. because if it is the trim pieces i wouldn't worry about the plastic paint because the trim pieces are hard plastic.
Old Mar 10, 2006 | 10:32 PM
mill$civic's Avatar
look in the DIY section in the forum..theres a step by step process on how to do it with pics and everything you need
Old Mar 10, 2006 | 11:46 PM
theemustangman's Avatar
Places That sell Professional Paint Products also have special Dyes for Dashs and other parts, might wanna check into that too
Old Mar 11, 2006 | 10:18 AM
Kedawei's Avatar
ORIGINAL: mill$civic
Checked the DIY, didn't see it.
Old Mar 11, 2006 | 12:05 PM
LEVIII's Avatar
FIrst sand it so it is rough and ready for paint. CLean it really well then use some adheasion promter then use primer then use paint then use clear coat.
bkp
Feb 1, 2013 09:38 PM
larlar73
Jun 7, 2007 02:19 PM
TicKeR_96_HaTcH
Jul 17, 2006 06:06 PM
rioredrex
Jun 30, 2006 08:55 PM
althius
Dec 20, 2005 03:50 PM
