pins
Old Jan 8, 2007 | 03:37 PM
dacool25's Avatar
Default pins
where can i find the plastic pins that hold the cloth to the back of the rear seats? anybody know the proper name for them?
Old Jan 8, 2007 | 10:30 PM
Caine714's Avatar
Default RE: pins
You can find them at an Auto Parts, they're pretty expensive though. Probably 3-4 bucks for a set of 2.
Old Jan 9, 2007 | 01:26 AM
POLYTHING's Avatar
Default RE: pins
its called PLASTIC-self snap-in-screw!
go to honda stealership and ask them! good luck
Old Jan 9, 2007 | 07:18 AM
Default RE: pins
I've actually heard that you can find them at Hardware stores for cheap. Just bring one in with you so it's easier to explain
Old Jan 9, 2007 | 06:21 PM
Default RE: pins
ya those are preaty cheap... those are nothing special simple plastic push in retainer....
take one to your local hardware store that sells nuts and bolts and such and youll be able to find them preaty easily....
ive got a big drawer just filled with different sizes lengths....
lowes/home depo also have them....
the ones that are harder to find is the removable ones... that have that center pin ya push down and remove the clip.... usualy if i break those i just use these cheap retainers.... same thing preaty much..
or if your realy cheap... if ya got a hotglue gun.... just glue the carpet/fabric material to the seats backing..... only need a few glue spots.... but only use hot glue... ya dont want anything that will dry hard or perminant... hot glue just needs alittle pulling and it will seperate just fine and be able to peel off and redue.
great stuff very versital.LOL
02civcoupe
Sep 17, 2006 08:29 PM
hondadelsoldrvr
Mar 17, 2006 12:50 AM
smokingemcee
Jan 26, 2006 01:15 AM
steven87ukuk
Feb 13, 2005 11:10 AM
RiceBurner
Jan 17, 2005 08:20 PM
